I have solution for youI am still looking at emulating the guard construction technique demonstrated in the Loveless video - and I am still pondering something: Loveless makes no point at all about having a sharp inside corner in the notch he grinds out for his bolster/guard - he just profiles it and sends it out for heat treating. *Yet* - there is this pervasive statement on this forum that one should NOT have a sharp inside corner, because this acts as a stress riser - and can/will lead to fracture at that point during HT.
Question: has anyone actually experienced a crack/failure of a blade, especially during HT, that started at a sharp inside corner?
In Loveless they make lot of knife , it is some kind of production .They must keep production as simple as they can .Slot in guard is milled and they leave that half round end because to make it square need lot more additional work , .Rounding on ricasso is more simple/ forgiving and faster step then to square guard slot .
natlek- i agree, its easier to round the ricasso than square the guard, but its flat on the utility knives i have seen. if rounding was easier, i figured they would do it on all the knives. there must be some reason they are different.
Thanks john. I never really set out to exactly replicate the loveless hunter ... just to use the profile for inspiration. Not sure exactly why but the geometry between handle and ricasso ended up requiring the tab in the front of the guard. Like you said - it should still work...cushing, just letting you know the drop point hunter has the tab for the guard to rest on behind the guard, and the utility has the tab in front of the guard. you are still in "loveless territory". he used both. are you using stainless or high carbon? the gap does not really seem to enlarge much after post heat treat finishing. the solder seems to have no problem filling the gap. you project looks good.
Oh ... and i am thinking i will not solder - instead use jb weld and peened pins. Soldering has been a little touchy for me, and ive had good luck with jbweld. Ive een discovered how to make peened brass pins virtually invisible...cushing, just letting you know the drop point hunter has the tab for the guard to rest on behind the guard, and the utility has the tab in front of the guard. you are still in "loveless territory". he used both. are you using stainless or high carbon? the gap does not really seem to enlarge much after post heat treat finishing. the solder seems to have no problem filling the gap. you project looks good.
