Cliff Stamp
BANNED
- Oct 5, 1998
Recently I set out to compare a few hones for a few purposes, one being to "prove" the superiority of leading vs trailing sharpening.
First the edge was set with a 600 DMT stone, results 7/29 lbs on a slice/push through 3/8" hemp. Lots of aggression, would shave and could push cut newsprint but catch in a few places.
1200 DMT, major improvement on the push, little on the slice, 7/20 lbs. Less aggression, but the huge jump in push cutting performance easily compensated. Could slice toilet paper readily.
15 micron SiC, little change, 8/19 lbs. I don't feel this was optimal, it was difficult to sharpen edge leading, the paper was on hardwood. Did not slice the toilet paper well.
0.3 micron AO, 6.5/15.5 lbs, much better, but the paper was cut with the knife in a bunch of places, very difficult to hone edge leadning.
0.5 micron chromum oxide on newsprint on hardwoods, edge trailing : 4.5/9.5 lbs, best performance I have seen to date. Cut toilet paper again but not as well as after 1200 dmt.
I was also measuring the sharpness on thread and cord, but there were problems due to certain parts of the edge being damaged from the paper plus I kept whacking the edge into nails during the hemp cutting because I forgot I had used the block earlier to calibrate impact drops.
What I did learn was that chromum oxide on newsprint gives a much nicer edge than on leather which seems obvious due to lack of rounding I think 1200 DMT + chromium oxide on newsprint should give a possible 50 / 50 sharpness on thread light cord (100 g), which I think is optimal.
In the above at the end it was 75/121, but that included the damaged edges, it was 65 / 65 in the best regions where the rope cutting was performed. Based on the ability to slice toilet paper after the 1200 DMT stone, it would be really nice to see a similar but finer flat diamond plate.
The newsprint buffing was really light, 20 passes per side on a 1"x3" strip of paper.
-Cliff
-Cliff
