- Mar 24, 2021
I've cut myself.. no sharpening needed lol.Sharpmaker with diamond rods will get my knives sharp enough to cut my fingers. Lol
I have the basic Apex system, and have added stones as I need them.Thank you! Yes there are lots of different systems out there and I will do my homework. Your personal experience with the Edge Pro and Sebenza's is very helpful. I just went to their website and saw two different kits: Apex and Professional. Which one do you use? Thank you!
Thank you.I have the basic Apex system, and have added stones as I need them.
Congratulations, I have seen a lot of positive things written about the Edge Pro sharpening system. Let us know what you think about it after using it a bit.Thank you all for your advise and suggestions. I just ordered an Edge Pro Apex 4 based on what I've read here and also YouTube videos for the different systems and setups. I understand there's a learning curve and expect to spend some time practicing. I hope you're all enjoying the long Memorial Day weekend, as we remember the fallen soldiers and their families.
Definitely will do!Congratulations, I have seen a lot of positive things written about the Edge Pro sharpening system. Let us know what you think about it after using it a bit.
Thank you. I have the Sharpmaker as well. Maybe I’ll give that a try.I use a Spyderco Sharpmaker for my CRK Mnandi and it works wonderfully so I really don't know whjy you had an issue with yours.
i had a Lansky at one time for a short while and I never did warm up to it. I ended up giving that away to a fellow coworker if I remember correctly.
I am a big fan of the Sharpmaker so I really can't help you when we talk about other guided systems. Sorry.
Thank you! I may have a try with the Work sharp sometime. I also have a Sharpmaker but haven't tried diamond rods. With my Edge Pro I matched the factory angle as best I could and it was nowhere near 17 degrees. I think it was over 21 degrees. I'm planning to change the angle a little at a time each time I sharpen until I get closer to 18 degrees or so. Thanks again!Work sharp guided, set @17* start coarse (320 dialmond) then 600 diamond) , strop with 2>.5 micron diamond spray on basswood or leather , should be insanely sharp
at worst sharpmaker with diamond rods, then strop green compound on cardboard if not diamond spray
The edge pro is a a awesome system!Thank you! I may have a try with the Work sharp sometime. I also have a Sharpmaker but haven't tried diamond rods. With my Edge Pro I matched the factory angle as best I could and it was nowhere near 17 degrees. I think it was over 21 degrees. I'm planning to change the angle a little at a time each time I sharpen until I get closer to 18 degrees or so. Thanks again!
I totally agree with you. The knife sharpened on my Edge Pro is pictured above. I plan to use it and resharpen often, re-profiling it as I go. It could be the heat treat as you say too. Thanks!!The edge pro is a a awesome system!
imo I would knock that factory edge off !! ( it could be burned) and re profile @ 20* or 18*
It's possible to polish the sides of a blade yet miss the apex, which from what you've described sounds like has happened to you.I totally agree with you. The knife sharpened on my Edge Pro is pictured above. I plan to use it and resharpen often, re-profiling it as I go. It could be the heat treat as you say too. Thanks!!
P.S. Thanks for posting the video.. it just showed up now. Didn't see it before.
I agree! You cannot put steel back. Thank you.It's possible to polish the sides of a blade yet miss the apex, which from what you've described sounds like has happened to you.
The Edgepro is a great system; I would go back to less expensive knives and practise until you (consistently) get the edge you want, and only then return to your prized possessions.
You can take steel off but you can't put it back on.
