Per the OP's specific mention of S30V, and the subsequent suggestion(s) to use an Arkansas stone:
For S30V, an Arkansas stone will bring nothing but frustration. Its natural novaculite abrasive is nowhere near hard enough to handle the vanadium carbides in S30V (vanadium carbides are ~3.5 times as hard as novaculite), and you'll grind on it for days without getting much done, likely ruining the stone in the process (by glazing it; the carbides will essentially polish the stone). It's the last thing I'd recommend for S30V. For simpler, less wear-resistant steels like 1095, CV, 420HC, 440A, an Arkansas can do OK. But not for S30V.
For starting out, an aggressive SiC stone (silicon carbide) or diamond hone will handle S30V much better; the SiC & diamond will at least do a decent job digging out the carbides for heavy grinding, and the diamond at finer grit will be best for actually shaping, thinning or polishing the carbides themselves. Tools like the Sharpmaker (alumina ceramic) can do touchups if the edge isn't too far gone, but won't be aggressive enough for major repairs (optional diamond or CBN rods are available for it, though). For repairing edge damage or rebevelling, you'll need something more aggressive as above. Take a look at values for hardness below, in deciding which abrasives might work best for the carbides present in some steels, as noted below:
Knoop hardness, for reference:
Diamond = 7000
CBN ('Cubic Boron Nitride') = ~4500
Vanadium Carbide = ~2800 (significant @ 4% and higher in CPM-S30V, CPM-S90V, CPM-S110V steels and others like them)
Silicon Carbide = ~2600-2700 (also called 'carborundum', it's used in Norton's 'Crystolon' stones and some hardware-store utility sharpening stones)
Aluminum Oxide and/or 'alumina' = ~2100 (used in majority of ceramics and other synthetic stones, such as Norton's 'India' stone, and the balance of cheaper hardware store stones; also used in many varieties of synthetic waterstones)
Chromium Carbide = ~1700-1800 (significant in steels like 440C, 154CM, ATS-34, VG-10, D2, ZDP-189)
Novaculite = ~825 (natural abrasive in Arkansas stones; works OK or well with low-alloyed steels containing no significant chromium carbides or vanadium carbides, like 1095, CV, 420HC, 440A and many others like them)
David
