Please follow this advice. Practice on some cheap kitchen knives you have around, a dull hunting knife in the back of a drawer, or even some inexpensive folding knives. Work on your technique until you get comfortable maintaining pressure and angles. Try a different types of steel (stainless and carbon) being used in blades of varying thickness and design. You don't want to scratch up your fancy new knives.Just a note to practice on cheap knives first! Everyone makes mistakes when they start.
Yes mate, you never stop learning.I've been freehand sharpening since I was a kid and I still find ways to improve each time.
You are welcome.Thank you for reminding me. I have watched his sharpening videos many times and just purchased a dual sided stone he recommends.
Yes, I have a couple of old kitchen knives and a folder I found in the dirt years ago that are in poor condition that I will start with.Please follow this advice. Practice on some cheap kitchen knives you have around, a dull hunting knife in the back of a drawer, or even some inexpensive folding knives. Work on your technique until you get comfortable maintaining pressure and angles. Try a different types of steel (stainless and carbon) being used in blades of varying thickness and design. You don't want to scratch up your fancy new knives.
Take your time and try not to get frustrated. I've been freehand sharpening since I was a kid and I still find ways to improve each time.
Thank you for that advice. I figure that even if the kitchen steel is different from the tool steel, at least I can get some practice at holding a consistent angle.Those cheap kitchen knives should be relatively easy to sharpen because they are usually made from inexpensive stainless steel. But sometimes they're not heat treated properly. Keep that in mind if you're having problems with any one specific knife.
And there could be a few bad spots on the edge due to the heat of the grinding process when they put an edge on the knife at the factory. Those spots could be softer than the rest of the edge. So just keep that in mind if you run into any issues with specific spots along the edge. I ran into this problem myself recently. The solution to that issue is to keep sharpening until you fully remove the bad spots. Once you do that, it's smooth sailing for the rest of the life of the knife.
Persistence is the key. I was still a teen when I was first learning how to sharpen. Now it takes me minutes to sharpen and edges often look almost as if I used guided system. But they usually get a little bit convexed over time. That's all normal. Just practice.So yeah, sharpening is hard. It looks easy in the videos. My paring knife is virtually a shiv now. Sharper than before, but I am having a hell of a time getting the bevels even on both sides, and the burr goes from one side to another and I never notice a moment where it releases. It just seems like it’s gone after I go back and forth between sides. The steel is whatever Global Japanese kitchen knives are made of, so I’m guessing the diamond stone won’t hog away steel the same on a 4V knive that’s high hardness.
The tip is the most challenging. Due to the curve of the blade toward the tip, I have to curve my sharpening stroke to match. My bevel gets screwed up there.Persistence is the key. I was still a teen when I was first learning how to sharpen. Now it takes me minutes to sharpen and edges often look almost as if I used guided system. But they usually get a little bit convexed over time. That's all normal. Just practice.
That will also get better with time. Just follow the edge and be relaxedThe tip is the most challenging. Due to the curve of the blade toward the tip, I have to curve my sharpening stroke to match. My bevel gets screwed up there.
So yeah, sharpening is hard. It looks easy in the videos. My paring knife is virtually a shiv now. Sharper than before, but I am having a hell of a time getting the bevels even on both sides, and the burr goes from one side to another and I never notice a moment where it releases. It just seems like it’s gone after I go back and forth between sides. The steel is whatever Global Japanese kitchen knives are made of, so I’m guessing the diamond stone won’t hog away steel the same on a 4V knife that’s high hardness.
I forgot about the Sharpie trick. Thank you for the reminder.It is tricky at first, but as said above, persistence is key. Try not to get too frustrated with it as you will get better with practice. A couple of pointers:
1. If you get to the point where you're chasing a burr from one side of the edge to the other, then you are probably ready to change to a finer grit. Maintain the same angles and light pressure until you start chasing the burr again. Eventually you will transition to hones (I prefer brown, then white ceramics from Spyderco) and strops, if you have them (don't worry about stropping now, focus on the stones first). The burr should get finer and straighter with each progression through your grits, eventually seeming to disappear entirely.
2. Regarding the tip, it took me years to figure out how to not only curve my stroke across the stone but to also slightly lift the handle upwards as the stone came into contact with the tip. Until you learn this little trick you will probably end up with slightly rounded tips. I will try to find a youtube video showing you what I mean.
3. Use a sharpie to color over the edge on your knife. Check the edge after each pass over the stone and you will see exactly where your edge contacts the stone and are therefore removing material. This trick will help you adjust your angle until you remove sharpie, and therefore steel, all the way down to the apex of the edge. Many people will sharpen their blades, removing so much material as to re-profile their edge while never fully reaching the apex, and get frustrated that their knife still isn't "sharp." This sharpie trick helps you avoid that, although the best indicator is feeling a burr along the edge (which you already seem to know how to do).
Welcome to the club. The only thing I could say is: ''practice makes master ..... if .... master makes practice''.but I am having a hell of a time getting the bevels even on both sides
Mr. Outdoors55 explained his method of burr removal in a few sharpening videos. Usually he doesn't progress through multiple stones. In most cases he only use one diamond plate - coarse or fine and a strop.and the burr goes from one side to another and I never notice a moment where it releases. It just seems like it’s gone after I go back and forth between sides
Looks good to me.I’ve been practicing for about 15-30 minutes daily. I used the sharpie trick today, and it is slicing paper off a coarse grit stone and a strop.
Congratulations on your progress.I’ve been practicing for about 15-30 minutes daily. I used the sharpie trick today, and it is slicing paper off a coarse grit stone and a strop.
