Âchillepattada
- May 17, 2012
I think mine is set at 22 degrees. I have sharpened my Ancient #2. I have taken some of the edge of the clamp over time where it was too close. maybe that was the differenceMy problem is that with an angle of 20 the sharpening bar touch the clamp and not the blade
View attachment 2242886View attachment 2242887
To maintain an existing bevel, I use a sharpie on said bevel and a loupe to verify that my stone is fully engaging it. If I feel like knowing what that angle is, then it's time to whip out the digital protractor.I've never used a clamp system, which makes me wonder how you guys line it back up perfectly after you've set your bevel the first time out... do you just look and see if the stone is connecting perfectly and adjust from there?
It can be a chore and lacks the simple joy found in absent-mindedly running the edge across an Arkansas stone -- thankfully, I do it very infrequently. Once the edge is established, I try to do as much as I can to keep it sharp through stropping and/or steeling. Also, for 1095 and similar steels, I feel like precision doesn't matter as much as it does on more modern steels, but for the modern steels, I feel like I'm not getting my money's worth if I'm not running the edge close to what it can support.Sounds a bit of a headache honestly. I somehow always imagined these types of systems would be dead easy to use. Never considered the clamp placement problem and actually maintaining the existing angle.
When I was using a guided system, I only used it to set good geometry once on each knife I sharpened for the first time. For me, that meant anything at or below 15° per side. Never cared what the exact angle was, per se. Only that it was within that limit and symmetrical from side-to-side. Once the new edge was set up with good geometry, I did all the touching up freehand. It's a lot easier doing it that way, if the foundation for the edge is set up well with the first reprofile and leaves some good, flat bevels that are easier to feel as the reference for holding the angle.Sounds a bit of a headache honestly. I somehow always imagined these types of systems would be dead easy to use. Never considered the clamp placement problem and actually maintaining the existing angle.
Sooo... what do you use now?I had a clamp-type system once upon a time. I retired it to where it belonged (the landfill) after figuring out that there was no way to establish a consistent angle over the entire length of the blade.
I have had the same sharpener for about a year and used it on some of my knives . With even wider blades than you are showing I have found that using the sharpeners angle indicator , 17degrees is about as low as I can go and still have a Secure Clamp on the blade . The biggest problem that I have found is the overhung weight of the knife handle . When I have time , I will try to remedy that situation because the basics of a decent sharpener is certainly there to save . It is just another tool that you have to use within the limits of the tool . With my knives that don't really fit this sharpener , I will just sharpen them free hand with diamond sticks . They are very quick and do the job .My problem is that with an angle of 20 the sharpening bar touch the clamp and not the blade
