Could anyone give me an idea on what would be a good way to sharpen a knife with this length blade?
I use a sharpmaker on my pocket knives and it works great.
Well, my thought was that making some kind of spring-loaded pinch that would keep them forced to the outside would be the easiest way to do that, what they're running into is tolerance stack-up between the rods and the plastic. I'd guess there's not ALL that much that can be done about it and still keep the price reasonable.
Drilling a triangular hole is amazingly tough, the machinists here at work tell me the bits for that are really pricey.
I might actually be tempted to just wrap a single layer of foil tape (like the HVAC aluminum stuff) around the base of the rod and see if that's enough to tighten it up. I'd guess it actually might be TOO much, and you may only need it on one side to completely remove the
Drilling a triangular hole is amazingly tough, the machinists here at work tell me the bits for that are really pricey.![]()
OUCH
I thought the Sharpmaker rods were round...
They may have a set of crock sticks with a round shape??
This reminds me. I tried it out a few months ago, and completely forgot. I have an old 'Kwik-Sharp' croc-style sharpener, bought probably 20+ years ago. Wooden base/storage box, made of cedar. It's round ceramic rods are 3/8" diameter and 9" long, and fit perfectly in the triangular holes in my Sharpmaker's base. With my base, at least, they're even more snug than the Sharpmaker's rods. With that in mind, some very commonly available 3/8" wood dowel, with sandpaper, might be a perfect alternative. The obvious advantage of wooden dowel is, it can be cut to length, appropriately sized for larger blades.
Might also be able find some aftermarket round ceramic rods, of the right diameter also.
I remember the very same set!! I asked my buddy "what the hell are you going to do with that contraption?" He informed me that it was a precision knife sharpener - "wtf?" says I and asked him to show me how it worked.
I was into the "biker" lifestyle after getting out of the USMC back then and knew nothing except free hand sharpening on oil stones. I honestly thought you could somehow drag your blade through the V configuration that it formed and somehow mysteriously sharpen your knife. We all wore Buck folders on our belts, in holsters back then and this sharpener was unlike anything I ever saw.
It had the wood case and really long ceramic rods - exactly as you described. Boy that was a long time ago and I think it only had one setting but it might have had a double setting like the SharpMaker?? Too much Jack Daniels, beer and bong resin to remember much more than that. Shoot that was in the 70's - a lifetime for some and more for others around here!![]()
When I have some better light tomorrow, I'll take a pic of it (or three).
I actually have maybe 6 or 8 different sets of the crock-type sharpeners, acquired over many years. I've been digging some of them out recently, and finding new appreciation for them. My hands are 'trained' now (finally), and I'm finding at least some of these 'old' systems aren't as troublesome or ineffective as I once believed. The rods in this set, in particular, are very good. And their extra length is a big plus. I touched up another knife today on them, using the 30 degree setting on the Sharpmaker base. By the way, my set only has one angle setting, and it's pretty wide, even wider than the 40 degree setting on the Sharpmaker. I think that might've been the reason I checked the fit of the Kwik-Sharp rods in the Sharpmaker base, to take advantage of the narrower angle settings.
Looks like a better build quality than a SharpMaker for sure. The one I saw had white rods, must been a different brand. I see the rods in the 30* back-bevel so I assume they'll work fine in the 40* setting for finishing. Thanks for sharing pics of that old classic.:thumbup:
