IMO the magic word when it comes to reprofiling & sharpening ceramic blades is "dampening": you will need to find ways to soften the constant impacting of the sharpening grits (be it silicon carbide, cbn or diamond) on the ceramic material, or you will end up with a crumbling edge as the ceramic has such a low toughness.
This crumbling effect will also increase as the knife edge gets progressively thinner from grinding/sharpening.
That's why i use the black silicon stone on the Tormek for reprofiling (since it basically grinds under water), as well as various Paper Wheels for the necessary refinement, since these have just enough "give" in them to smoothly sharpen ceramics (when used with diamond compound)
I have no experience with using a DMT plate for sharpening ceramic knives, but when these were all i had i would probably take my finest DMT plate and try to sharpen the knife while holding both the plate and the knife under water, using indeed the edge trailing method with light pressure.
No guarantees, but i have a hunch it might work.
Remember that if it does the resulting edge will need refinement, as you don't want a toothy edge on a ceramic knife.
Fine wet & dry paper will work (be it slowly), but maybe you can even find some diamond paper.
