I didn't see it as trolling either. I guess I have talents I was unaware of.
DD
Trolled so hard they moved your thread
[Youtube]Cdiz0k0Rudw[/youtube] .
No reason for the troll song other than I'm really sleepy, and it amuses me.
DD
Exactly the way Melvin does.
However, if it were a nice Randall that I might sell someday, I wouldn't sharpen it at all. What would be the point? I have plenty of perfectly good users if I need a sharp knife.
But I think the point may have been missed. The instructions are not advocating honing the knife. They are instructing the owner to lay the blade flat on the stone. That's not honing. That's re-shaping. I knew an old cowboy who used to sharpen knives that way. Ruined some really nice ones too.
DD
I use crock sticks set in a V pattern in a wooden base to realign an edge when needed, then a leather strop glued to a wooden paddle that I screwed onto my work bench. Dull to very sharp in about five minutes or less - with no metal removal... :thumbup:
That's not what the instructions are "advocating". They are suggesting you could do that, but they explain that laying the blade "flat" would result in an edge that is fragile... They recommend instead the usual low-performance industry-standard of 20 degree per side (40 degrees total) which are not edges but "wedges", and which require so much effort to cut anything with... (They typically ship with "wedges" over 30 or even 40 degrees per side, meaning they come with hardly have any edge at all, the purpose I suspect is to minimize heat build-up on the edge at the factory: This "non-edge" is even said to be hand applied for this reason, and it does pay off in edge holding if you finish it by hand.)
The edge as it comes from Randall is usually ridiculously open-angled and dull, but that hardly matters, since almost all of them have very thin edges grinds, typically 0.020" at the shoulders, mounted on deep, or shallow, hollow grinds, this combination making them very easy to re-profile to whatever angle you prefer, as "suggested" in the instructions...
This is the whole point of a Randall knife...
The idea of leaving a Randall in its dull factory condition is really an outrage to the intent of its design... The are moderately priced roughly finished user knives of excellent performance... They are definitely heirloom quality, but hardly rare or out of production, or really that expensive for the performance they offer (which is outstanding, particularly in stainless), so I really don't understand why putting a hand applied edge to them is unthinkable... The hollow grind is why the edge doesn't thicken over time, keeping the exact same cutting performance for generations of rough sharpening, this being exactly why they are so beloved, and why they don't lose their value... Hand-applied edges is what every feature of what they are is designed for, unlike the current infatuation for recurves, the convex edge nonsense, or even the overrated Full Flat Grind, which inevitably thickens over time...
Gaston
I agree:thumbup:Gaston, I bought a Randall as my first knife to use every day for just the reasons you wrote - your post is spot on as far as my decision making went
Thanks
