Hello gentlefolk of Bladeforums!
I recently acquired a Puma Solingen 88 straight razor and while it came sharp, it didn't come shaving sharp. The blade looked to me as having never been sharpended before and the seller told me so as well.
All my other EDC and kitchen knives get sharpened on a DMT Duosharp, which works really well. I didn't want to sharpen the Puma on the DMT, so I got a (cheap) whetstone by WMF, supposedly a 500 and 1000 grit. After finding out that "finding" the sharpening angle on a straight razor is really straightforward (I lay the entire blade flat on the stone, spine and edge aligned) I got to work first on the 1000 grit side, since the blade had an edge on it. After a couple dozen strokes on each side I went to stropping it (again, laid the razor flat onto the strop and with almost zero pressure) and then tried to cut tissue paper. Which didn't work as well as I thought it would, especially since all the other knives I sharpen on the DMT will cut said paper.
Edit: Forgot to mention, I tried shaving with it when I got it, which was virtually impossible, after my sharpening efforts it was better, meaning I could shave with it, but it was rough and my face is not nearly as smooth as I know it can be!
So I come to you with questions:
Is it correct to lay the blade flat onto the stone and repeat the strokes with very light pressure?
Could it be that I just didn't sharpen long enough? As said, I'm used to diamonds, the time I put into the razor on the waterstone would've made every other blade on the DMT extremely sharp ...
Or could it be that I didn't use enough pressure, though I could tell that material was being removed?
Thank you for reading and for all potential answers! Have a nice day!
Chris
Chris
