For my guided sharpener .1 degree is the most difference between stones I can have without it affecting my sharpening with coarser stones, with the finer ones it may be noticeable, depending on the width of the bevel. IMO the whole point of using a guided sharpener is repeatability. If your angles repeat perfectly all you need to do is remove the scratches from the last stone, if they don't repeat then you need to set the bevel as well which takes a lot more passes to achieve.
