- Nov 17, 1998
What sharpening angle is used on Busse knives?
I sharpen INFI at 18dps no micro bevel which works fine on hard wood like camelthorn(hard as bone). Normal hard wood I will go to 15dps. I do not use sr101 anymore but if you do it needs to be at 20dps with 25dps micro bevel on hard wood.
sr101 really that brittle? 12c27 can cut hardwood at 7-8dpsI sharpen INFI at 18dps no micro bevel which works fine on hard wood like camelthorn(hard as bone). Normal hard wood I will go to 15dps. I do not use sr101 anymore but if you do it needs to be at 20dps with 25dps micro bevel on hard wood
12c27n /.6% carbon, very tough.sr101 really that brittle? 12c27 can cut hardwood at 7-8dps
Excuse me, made a mistake. It should be 12c27 can cut hardwood around 10-12dps with no significant damage, just slow wear. why can’t that work? 12c27 is a fantastic steel, it has great edge stability.12c27n /.6% carbon,
Cut hardwood?
Sounds about perfectI would say that you are fine at 15 dps for any busse steel.
I took this knife accidentally down to 8.8 dps. Not intentionally. I miscalculated my triangle. I chopped about 8 cottonwood 4-6 inch branches that I had to reduce in size and it held up fine on that wood.
Then I decided that I would hack into bunch of thick copper tubing and did so to see if I could induce fracture. All it did was create a rough burr on the edge, probably due to the thin edge. I was able to steel it off
Cliff also took his old SHBM down to 8dps and processed tons of wood with it, with little damage. He did have some rippling because the steel was so thin. but no fracturing. The original knives were running 2pts harder though. That does make a difference in resistance to deformation.
sure. You know, Mora knives are sharpened at around,10-12 dps, just take a companion in 12c27 and cut hardwood to see if there is any significant damage beyond slow wear. First saw this from Cliff Stamp YouTube video, then I tested with Mora with 10-12 dps factory edge, they can handle it no problem! and note that falling axes are only 7-8dps, I don't think sr101 will have any issue at 15dpsEven at 10-12 dps, I'd love to see this. Let me know where you saw or read this. Thanks
just checked Mora knives are 11.5dpssure. You know, Mora knives are sharpened at around,10-12 dps, just take a companion in 12c27 and cut hardwood to see if there is any significant damage beyond slow wear. First saw this from Cliff Stamp YouTube video, then I tested with Mora with 10-12 dps factory edge, they can handle it no problem! and note that falling axes are only 7-8dps, I don't think sr101 will have any issue at 15dps
Depends on the wood. 15 dps won't work on African hard woods(camelthorn/like bone). I followed Cliff Stamp for a long time. I use to test lower angles on hard woods like camelthorn.sure. You know, Mora knives are sharpened at around,10-12 dps, just take a companion in 12c27 and cut hardwood to see if there is any significant damage beyond slow wear. First saw this from Cliff Stamp YouTube video, then I tested with Mora with 10-12 dps factory edge, they can handle it no problem! and note that falling axes are only 7-8dps, I don't think sr101 will have any issue at 15dps
that's for sure a damn tough wood if it can chip sr101, which can chop wire like wood. How about infi vs African wood?Depends on the wood. 15 dps won't work on African hard woods(camelthorn/like bone). I followed Cliff Stamp for a long time. I use to test lower angles on hard woods like camelthorn.
At 15dps sr101 becomes a serrated blade, I tested many samples. 18dps with a steep microbevel did ok. 20 with a 25 micro if you want minimum to no damage.
I like mid carbon steels and agreed with Cliff it made more sense in large knives which took a beating because of toughness and ease of sharpening.
If you really use a knife week after week you realize that you will damage the Apex from time to time NO MATTER THE STEEL, so ease of sharpening is really worthit. I like toughness and corrosion resistance.
