Sharpening Angle on Busse Knives?
I am glad you picked Mora, because they do have excellent steel.
So, I have a ton of Moras because they are efficient tough and cheap. I also have the companion. The edge on the companion is 13.5dps. Still very thin. But there is a serious issue you are not taking into account. No matter how hard you try, you cannot develop the impact force with a mora than you can with a large heavy knife There is no comparison in terms of force exerted on the edge in a mora vs a heavy chopper or even a medium sized large blade. Batoning does put stress on the edge, but again, you are going through small wood with a small knife. Large wood batoning is much tougher with large knots etc.
As for axes, no felling axe has an angle of 7-8dps. On gransfors bruks own website, their sharpest angle is for carving and that is 25dps. For chopping they go more obtuse than that
1: For cutting hardwood or frozen wood
2: For cutting softwood
3: For carving. Angle 25º – 30º
4: Wrong grind
Tis tells you how hard chopping is on an edge. No comparison, you need a lot more edge toughness on a big blade, than you do on a small blade. INFI is literally overkill on a small blade.
so when I used the knife about at 8.8 dps, the blade grind being flat is much thinner than any mora. Less metal behind the edges shoulder than a mora. The stock was so thin it did ripple slightly. But never tore or chipped.
Have you compared the knife in the video to more recent INFI?
So moral of the story. On a smaller knife go SR-101 and on larger knives go INFI :)
I think an edge angle of approximately 23-25 degrees per side would be best suited for most Busse knives.
I recently took an SR77 Son of Dogfather down to 23 and it is really great now. Was a bit thicker from the shop.
I chopped a bunch of ice and ice blocks with it today and it was a lot of fun.
At this angle I can dig with it, but it will also slice well.
I have a Ratmandu in SR101 at 19 per side that is also great.
Here are the knives:
Son of Dogfather with a friend:
Ratmandu:
Here is a mean street at 21 degrees but a fine grit. Also SR101.
And here is an INFI Son of Badger with a zero convex edge by Ban Tang:
