So Hob and Jeff I assume then that both of you feel that the angle of the relief bevel behind the Micro bevel is important? It needs to be at a Spyderco preset?
Serious inquiry ok? How is your knife diminished by just laying it flat on a course stone then slightly raising the spine and grinding a relief bevel. Refining it to what ever degree you want to, then cutting a micro bevel?
What is gained from what appears to me to be a religious devotion to Spyderco presets? Propping a stone up against that Tri angle stone has got to be harder to use than just laying the stone on a table as they were designed to be used?
Not trying to be a smart ass.... But what am I missing here?
No advantages to what you are describing and hell no, it doesn't need to be a Spyderco preset. But
a) A lot of people are scared of free handing and the coarse stone with the Sharpmaker is an easy entry to sharpening, you can hardly do anything wrong and the results are excellent
b) When I am using angles as large as on the Sharpmaker, I really only want a microbevel, not a macro bevel. So I use the 15 deg not just as a relief, but take the bevel all the way to the edge and start already to refine it. I use the micro bevel only as a means to really clean of the edge with no more that a few strokes, so angle control becomes already important. Of course on a simple relief grind this is not very important.
c) A lot of people have trouble holding an angle free hand without any guide and also have trouble holding the same angle on either side of the blade, yet they are often concerned about the aesthetics of their knife. Your technique combined with an unsure or unpracticed hand usually leads to uneven bevels, scratches on the blade and asymmetric grinds (left side a different bevel than right side). I can take the Sharpmaker and coarse stone with me and can rebevel my fathers knives in the midst of Christmas dinner preparation while holding a chat, I can not do that free hand even though I am relatively practiced holding an angle.
Of course the Sharpmaker technique has some shortcomings as well. You are never able to lean into a coarse stone with it, which makes rebeveling even with a coarse diamond stone slower than it would be, if you would lay the stone flat on the table and freehand it. So, no adherence to the Sharpmaker presets, but the Sharpmaker is a great tool and since it has the presets you use what you have.
Personally, I actually mostly freehand, except if I am in a hurry or if I am on the road. I use selfmade angle blocks, that I use to "train" my hands to hold a certain angle and then I free hand using waterstones. I use specific angles for aesthetic reasons and it saves me extra strokes that do not help any (efficiency), when falling back into the bevel. I am using mostly a 12 degree bevel with a very few strokes (about 6 per side) at the very end at 15 deg. Since I don't use the Sharpmaker, I don't use the presets. 12 deg I just found to be a nice compromise between convinience (less material to remove) and performance and it is above the angles at which people have reported problems with the high carbide steels. 15 deg I use because I think that the microbevel doesn't do what it is suppose to, if there is not an appreciable difference between the edgebevel and the microbevel. I find 3 deg the absolut minimum.
Finally, specific angles help to determine performance differences. This way I can check how much I gain, when lowering the angle by, say, 5 deg. That is purely for my own personal benefit though. But it also helps a beginner to give him an idea how low you should go. Imagine a beginner sharpening his first good knife. You tell him that it doesn't matter and he tries your technique and sees that the edgebevel gets much wider than it came from the factory. Now he gets unsure and either complains about a scratched up knife or returns to sharpen at factory bevel and asks, how he can match it. With actual angles you can tell a beginner. That 15 deg per side for example is not to low that he should stick with it and ignore the factory bevels
