Jason B.
- Jun 13, 2007
Those cost about twice what I'm talking about. DM
Gotta pay for performance.
in indonesia that stone very expensiveA SiC Norton combination coarse/ fine stone will eat D2. DM
can i sharpen d2 with corondum
Sharpening is an art, and those big sharpeners are like trying to paint a masterpiece with a wagner power painter instead of a brush.
I have no idea what the above post was trying to correlate, nor its reference. Does anyone?
D2 is nothing but it’s martensite matrix and chromium carbides. D2 is a relatively simple steel and is composed of chromium carbides and the surrounding martensite/cementite with a very tiny smattering of vanadium (depending on the D2 source itself). Use a stone that will cut chromium carbides, as they are harder than martensite and cementite for “best results”. AlOx will do the job especially in the coarsest grits to establish the edge itself, (best with “hard” stones in this category). SiC stones will eat it for lunch. So will CBN or diamonds.
That is all there is to it. Besides proper sharpening technique. But as for what D2 needs to be sharpened well.....you certainly don’t need theoretical nonsense.
For best results, a coarse stone of AlOx will cut and establish the edge bevel. To refine the actual edge apex, a SiC stone is plenty hard enough. CBN or diamonds will be that much faster. But for actual sharpening, D2 is a pussy cat.
Skill not tools my friend, don't worry about fancy stones.can i sharpen d2 with corondum
NopeLooks like the issue is living in a part of the globe where access to even the cheapest stones here are not as available or affordable. Indonesia doesnt sound like a fun place if you like to sharpen
Corondum is just Aluminum Oxide, which isn't a "fancy" stone. It will sharpen D2, especially in the coarser grits. If I had the option of Crystolon, tho, I would use that instead. It's Silicon Carbide, harder than AlOx.Skill not tools my friend, don't worry about fancy stones.
A crystalon isn't a fancy stone either. Go figureCorondum is just Aluminum Oxide, which isn't a "fancy" stone. It will sharpen D2, especially in the coarser grits. If I had the option of Crystolon, tho, I would use that instead. It's Silicon Carbide, harder than AlOx.
To hijack, what finish do you leave on your d2? I usually apex with Spyderco ceramics, but didn’t like it on the only d2 blade I own. Could’ve been user error, but it didn’t seem very sharp until I went back and made a toothy apex bevel with dmt F (~600 mesh).
Diamond has been my preference for D2, at higher finish. Especially in stropping D2 to a higher polish, I've noticed it's more prone to edge-rounding and loses it's bite, if I go too far with AlOx polishing compounds especially. To fix that after the fact, I take it back to DMT EF (sometimes follow that with EEF) and then polish with 3µ diamond paste on a hard substrate (I use basswood for that). Leaves the edge much crisper that way, at high polish.
Correctamundo. You don’t need fancy stones for D2. All D2 isn’t the same. Some have higher vanadium close to and above 1%, other D2 is lower in V content. Just like David mentioned , not all AlOx stones are the same. Some have harder binders than others. As to if that is better depends on the stone itself.A crystalon isn't a fancy stone either. Go figure
