According to Sal, all Spyderco knife steels can comfortably support 15 degrees-30 degrees inclusive.what is the best sharpening degree for VG-10 knives?
A few days ago, I sharpened my Street Beat (with VG-10 blade) at around 10 degrees per side, then finished by adding small bevels with the Sharpmaker at 15 degrees. So far, no problems at all. I cut some thick cardboard and then looked at the edge under a microscope. There were no chips or tears or anything. I also used it to cut up steak on a ceramic plate. The edge was very slightly dulled, but there was no damage.
IIRC, Sal was carrying around a Street Beat that had been sharpened to 7 degrees inclusive, which I guess would be "flat to the stone". I wouldn't want to go that extreme, but I think Sal uses very thin edges sometimes to test what a steel is capable of. He could probably give you a better idea of what the angles are that VG-10 will work best at.
I have an old Calypso Jr. with a VG-10 blade that needs its edge thinned out. Since I just got a new coarse Diasharp hone, I'm probably going to reprofile it in the next couple of days. I'm thinking that I'll do about 10 degrees per side, but I won't add a micro-bevel and I'll try leaving it somewhat coarse. It should be interesting to see how that kind of edge performs in VG-10.
i have a question, but it's not really related to this topic but i don't want to make a new thread just for it so.. what is the smallest degree i can get with the spyderco sharpmaker? i've read it's only 30? or am i wrong?
Neat. If you could please give the link to this post? :>
18 per side is the official factory-edge on most VG10's (Police, Delica, Endura)
but, proper VG10 can easily take 10 per side.....if you want it to
Just wondering where you got the 18 per side info, Agreed wholeheartedly that they can handle 10 degrees per side, that is what I put my Enduras at, with a 15 degree microbevel, and they have no durability issues.
found it...yet again...
http://www.bladeforums.com/forums/showpost.php?p=4154076&postcount=11
(VG10: 18/19 per side, CPM's: 15 per side)
