Hi,
try unglazed bottom of cup, free brick , get shaving from ~$10 hardware store stone
For all intents and purposes, I am an idiot when it comes to sharpening. I know absolutely nothing on how to sharpen because I am pretty new in the hobby in general, but I would like to learn. Where do I start? What all will I need and what should I have? Where is a good place to get those things and how do I pick a sharpening system?
I read all the stickies and I'm still not sure where to begin.
Hi,
I know the exact feeling,
I've been there myself a couple of times,
absolute beginner should skip the stickies
you need hands on experience
go into the kitchen and grab a paring knife and a coffee cup , or a couple of cups or bowls, anything with unglazed ceramic on the bottom, thats your sharpening stone
Take a few minutes , turn cup upside down, and get some experience sharpening freehand ... then come back and ask more questions
it doesn't take a lot of equipment or high grits (like coffee cup)
or skill to cut some paper or shave arm hair,
just don't wobble the blade too much as you rub it on the unglazed portion of cup ...
keeping thumb on spine helps with wobble/keeping angle ...
see an old boyscout (
jackknife) do it its
Instinctive Knife Sharpening
if blade isn't a butterknife, just guessing and rubbing the blade on a coffecup will improve the sharpness
See a first timer copy the internet 20 pulls around a cup
Sharpen a knife - Katie Robichaud
And see a sharpener do it like his mama
There is no excuse to have a blunt knife! - stefanwolf88
Yeah, like the guy says its not the best way, but does work and is
available in every kitchen, and it'll work quickly on any knife that was sharp sometime in the last five years
any knife with edge that doesnt look like a butter knife -- I wish I figured it out years ago instead of relying on steak knives and buying new ones every few years
What they're doing with the coffee cups is microbeveling and/or "steeling"/honing/burnishing, by using high angle by instinct (guessing, essentially 20-30 degrees per side ), doing that will straighten any rolls , and also sharpen the apex, basically you'll see results real fast, but after a few sharpenings,, you'll have to do more
So start with instinctive sharpening, try it at least three times, slice some printer paper or cut some bananas
Come back and talk about what you did and what happened, ask questions...
Next thing to try would be
sharpening with a brick[/b] which includes some brick/stone maintenance...
if you have a free brick and you like to play
Next thing to try, a considerable step up from a free brick would be a basic double sided hardware store stone , like ace hardware( $3.99-$14)
After the coffee cups get a basic hardware store
If you have a sharpening stone, or a brick, these would be the follow up video to the coffee cups (actually video after that), try it with your std. dry stone
basic sharpening, raise a tiny burr, cut it off at elevated angle, shave how to sharpen a knife - Joe Calton
Good follow ups
Similar method (three step ) with a one dollar stone
? Cheap sharpening stone - does it work? - stefanwolf88
Extreme low grit sharpening : clay brick - Cliff Stamp
Thats almost all the secrets of sharpening freehand right there, easily get to shaving sharp with that info, and if you use a light touch, whittle hairs.
After you've sharpened a dozen times, watch the videos again, ... a lot of info you won't really appreciate until you try sharpening, don't watch too many videos before practicing
Come back and tell us how it went, ask questions
No luck with freehand? Try guided freehand or even jigs
There are all kinds of free devices you can make... some don't even require making
leaning your sharpening stone against a wall or book to make a
bench stone sharmaker and just slice down the stone and pivot for tip
make one from paper, fold plastic V, mini clothes pin , gluesticks, wood ...
Simple sharpening jig - stefanwolf88
How to Sharpen a Knife with Paul Sellers
