Cliff Stamp
BANNED
- Oct 5, 1998
Yeah, I think it mainly comes down to lack of understanding of what needs to be achieved. Usually a few minutes worth of instruction solves all major problems.
-Cliff
-Cliff
Actually the best reason IMO for controlling bevel angles and edge geometry is to make studying of performance more meaningful. My knives seem to be in a state of always being studied anymoreYes, that is what Lee recommends but you should be a little more focused as it is ground to the same actual constraint as the edge (minimal cross section for durability) but in most cases outside of the extreme (heavy tactical) that is often reduced to the lowest you care to grind. I just grind them all basically flat to the blade, even for large chopping knives which get only a few degrees of "roll" as Fikes demonstrates, as the primary grind is usually about 5 and I want the relief grind for the edge to be about 8-10 at maximum.DoW said:All of which leads me to conclude that when sharpening freehand it's much more practical to not worry about accuracy when cutting relief, just make sure it's substantially more acute than you want the final edge.
I'm interested in what kind of secondary bevel you're adding to knives when running the primary/relief at 8-10 degs.
Interesting too how edge optimization for a wide range of uses actually involves only a fairly narrow range of angle.
Hope to see this kind of thing on the website .... and BTW nice choice of domain names.
The only way I can see to resolve those kinds of disagreements and all the ambiguity is systematic testing and measurement, ideally with a number of contributors.
I assume like you've done with reviews posted to your site any potentially interesting topics could be posted and linked to here .... I can see how this could promote discussions that are geared to the interest levels of all.
I think some people misinterpret an interest in comparative, quantified results, for me it isn't in any way being uninterested or unappreciative of experienced opinions, I enjoy hearing what people think when they describe their experience in any kind of depth .... it's just that the only way I, or the next guy, can confirm or build on someone elses work and findings is if the work performed is adequately described and the results quantified.
