- Dec 2, 2005
if I weren't so darn old and set in my ways, I may go get a mouse pad and some 600 paper. Very impressive!!
In truth, that's all that's stopping me Carl!
Just an update. I couldn't get the Sharpmaker to work so I obtained a Lansky guided Arkansas hone set plus a coarse diamond hone. I reprofiled the edge of the Northwoods Burnside using the diamond hone on the second lowest guide hole (nominally 20 degrees). Once I got what looked to be an even bevel on both sides of the blade, I worked my way through thr Arkansas stones ending with the black one.
Now I have a sharp knife and I noticed the edge cuts paper cleanly but feels as if it has less drag than the sharp factory edges I've experienced on Spyderco VG10 and S35 knives. I don't know if this is a function of the 1095 steel or the hones. It isn't necessarily better, just a new experience for me as I've never had a 1095 knife before.
Every GEC knife I buy gets reprofiled on the Sharpmaker on the 15 degree side. I use the diamond (I think they are diamond) to really get aggressive at removing the steel and getting that nice bevel. Then working my way through the medium, fine, ultra fine and then strop. This has worked for me and I'm really happy with the results.
The Sharpmaker has worked well for me on a lot of my knives but on this GEC, it wouldn't contact the right bevel of the blade. No issues with the left. It seems the right bevel was cut significantly shallower than what the 15dps side could handle.The best tricks to success with the Sharpemaker is patience, persistence, and clean stones. It takes a while to get the angle set on the blade, as David mentions factory edges are toothy and can be inconsistent. Keeping at it will pay off, provided your technique is solid and not "all over the place". It's easy to roll the wrist and wreck your angle and progress. When the stones get loaded with steel, they stop removing it and makes things frustrating. If you can drag your finger across the stone and you have black all over your finger, time to wash the stones.
I agree, invest in a pair of the sharpmaker diamond rods. They really make re-profiling a breeze on the sharpmaker.
I splurged and purchased a set of diamond sticks for my Sharpmaker, and it is the best sharpening investment I have ever made. I start with the diamond sticks at 30 degrees and keep going until I have a sharp edge, and then go down to the black sticks, and finally white ceramic. It takes a while to get the initial 30 degree bevel with the diamond sticks, but every knife I have put to these has come out sharp.
If I am going to use the blade for whittling, I leave it at 30 degrees. If I am going to use it more for general purposes, I will sharpen the edge again with the 40 degree side of the Sharpmaker, but start with the black sticks (coarse) and then finish with ceramic. It only takes about 10 strokes on each side of the knife to get this secondary bevel.
From that point forward I simply strop my knives after I use them to keep the edge razor sharp. If I am using a knife heavily (like when whittling) I will often stop and strop for a few minutes to keep the edge from flattening too much. If I am using a knife lightly, I strop at the end of the day, or sometimes after a few days.
