- Apr 12, 2009
After say 100 passes each side on sandpaper can I move to coarse stone and then continue on?
It depends. How coarse is the sandpaper (what's the grit rating on it?), and what kind of coarse stone are you using? I'm trying to get an idea of how the grit compares, between the two. It might be redundant or counter-productive if the coarse stone is as aggressive, or more so, than the sandpaper. If that were the case, you might be able to move to a medium grit instead. My personal preference is to finish with the same type of media as I began with (sandpaper, in progressively finer grits). It's easier to predict the finished results that way, as the abrasive type is consistent, and only the grit size is reduced in a sensible sequence.
Also, I don't generally count the number of passes. That varies widely, depending on steel, pressure, technique, etc. I'm in the habit of frequently testing/inspecting the edge as I go. When I've verified that a burr has formed along the full length of the edge, or that the edge is cutting nicely, that generally tells me it's time to move to the next grit.
