When you sharpen one side of a knife, eventually you will have removed enough material that a burr is formed. This happens when the edge you are sharpening is sharpened down to the point where it meets the other edge and forms a burr where the two angles meet. When you sharpen, the goal is to sharpen one side while maintaining as constant an angle as possible, untill a burr is formed along the ENTIRE edge. Then, flip it over and repeat the process, again, untill you have a burr along the entire edge. Once you get to this point, it's time to switch to a finer stone to REMOVE the burr. A burr left on the blade is what's known as a wire edge. It's very sharp, but it will fold over and become dull in a heatrbeat. At this point, on your finer stone, make one stroke, lightly on each side, alternating for 3-4 strokes. Stop and check for a burr. The easiest way to check is ot use your fingernail right at the edge to see if it catches. The burr must be removed from the entire edge to be sharp. Be sure to check both sides. You can also increase your angle slightly and hake a couple of alternate strokes. This method is called "double edging" and it works really well, it's the method I personally use, and alot of other folks arround here too. Hope this helps, if you need any more info, drop me a line, I'll be glad to help. Good luck.
