- May 23, 2010
look at this video,it make provide a better understanding......
http://www.youtube.com/watch?v=PgPI_Gs117c
There was some really good advice given before this post. Terrible advice. The OP doesn't want the knife "sharp enough". He wants a good convex edge. And flicking your blade across a stone a few times is no way to take care of your knife.
You do realize were talking about a convex blade here?
the give of a paper wheel does give it a slight convex edge in reality.
So I'm gonna try the sandpaper mousepad method again today with a black marker along the edge.
I read someplace that convex edges aren't supposed to be crazy sharp because that would make the edge thinner and it would roll/chip. Is there any truth to this?
Also should the edge angle be acute or obtuse? I think I was sharpening it at around 25 deg and it looks like a micro V that I have created. Is that the idea or have I done something completely different.
Sure it does![]()
Oh for crying out loud, it's a piece of steel.
flick it across a stone a couple of times and it 's sharp enough for what ever you would want to do with a F1.
It's not rocket science.
Don't scare the guy by over complicating things.
The first thing I want to say is: there are many, many different ways to sharpen a knife, and they all work. We as individuals are all shaped differently, we think differently, we have different body mechanics, differing levels of intelligence, intuition, dexterity, experience, etc. What this means is that what works great for one of us may not work for all of us. It also means that for one person it may be easier to use a method that is more difficult for others. This doesn't make either method right or wrong, nor better or worse.
...In conclusion, let's all try to keep that in mind when we make and/or read a comment (especially when making a suggestion; keep in mind that what may work for you may not work well or as well for someone else because of the reasons outlined in the first paragraph). We are all here because we like knives, especially sharp knives, so we oughtn't really be at each other's throats so often, when really we all have the same goals in mind.
That's usually because you're sharpening at a different angle with each stroke. I did that to my ZT 0301 and while it looks like a convex edge, a good light will reveal the truth. Then I took the edge to my Work Sharp and put a true convex edge to it.the give of a paper wheel does give it a slight convex edge in reality.
One thing I know I don't like is a polished edge. It may be pretty but there's lots of stuff it just can't cut! Like...rope or a tomato. Hardly survival like...huh?
True. I've dropped more than one tomato on my polished edges and had them split clean in half.I was completely on board with everything you were saying in your post until this statement. This is false. A properly polished edge will cut through anything a non polished edge will cut through. In my experience, a polished edge will usually cut smoother and easier than a non polished edge through all types of different materials. As I said, this is in my experience.
But I did run into one thing that couldn't be cut with my edge:
Hard plastics.
More specifically those zip ties. For those I prefer to use the wood saw on my Swiss Tool(scissors seem a bit dull).
Actually it wasn't false Tony...I said "I" don't like working with polished edges. I'm well aware of how valued highly polished edges are to most. I did present it incorrectly though and thanks for pointing that out.
I was actually relating how my S1 Forest performs with a polished edge. I'm serious, the blade is so thick that it will mash a tomato before it slices it. As Ben (EdgePro) says in his videos (cutting efficiency has more to do with blade geometry than with how polished the edge is). So, a Santoku (1.9mm) that's somewhat dull will cut through a tomato far better than an S1 (5mm) that is razor sharp. Now given the same instrument; Santuko, one dull verses one polished, I'm in todal agreement with you.
In Ben's videos he talks about how certain knives do better (or worse) with certain finishes. For example, my S1 would skin a deer and slice meat from the bone far better polished than not. But I believe a fillet knife needs the micro-serrations to cut through a Walleyes back. I think you get what I was driving at. I also agree that you are indeed right given the correct tool for the job.
So for a survival knife "I" would prefer a finish with more micro serrations. They just saw better that way. For a pocket knife like the Sebenza or my U2 (Laminated SGPS HRC62) I prefer a polished finish.
Does that make better sense? Again, I was only voicing my personal preferences. I did not mean to offend.
