It depends on what you have? You could get one of those 1" belt grinders from HF. Run the blade length wise along the upper wheel.
This is how I sharpen my mower blades too. Only thing I would add is I really like this type of grinding wheel as they work excellent for this type of grinding:I cut 40 yards a week and I rotate with 3 different sets of blades. Us a 4.5 angle grinder with a disc that is not very aggresive. Grass blade are chisel ground. Don't make the angle different than stock.
There is really no point in putting a fine razor edge on a lawnmower blade, after the first lawn it will be pretty dull, plus it increases the the chance of chipping.
*A couple years ago renowned bladesmith Kevin Cashen was talking about welding hardened D2 inserts into his mower blades so they would hold an edge and give him a cleaner cut. That's a bit further than most of us would take it![]()
I would be at least interested in what the additional cost would be over regular blades. Not D2, but maybe 3V or S7. Something super tough to resist chipping. About 3/4 of the way through last season, I had some uneven cutting due to chips from small twigs I suppose. If I could go a whole season without messing with the blades and have a clean cut, it might be worth it.
i use a magnematic 8000 i own my own buis cutting and landscaping,they are pricey but faster and really no better than my $15 angle grinder from harbor freight.
