- Apr 12, 2009
At times, I've experimented with techniques that run essentially parallel to the edge. Mainly I was doing this in searching for a stroke that keeps the angle steadier and more consistent, and it did help with this to a large degree. The downside I noticed, was that it eliminated most of the 'bite' from the edge, even when doing so on a coarse stone. So, if I used the technique at all, I did so only to set bevels or otherwise establish the geometry; then I'd follow up with perpedicular or diagonal strokes to re-establish the grind lines that make up the 'teeth' in the edge.
I'd think there could be circumstances when a parallel stroke on a coarser hone might effectively 'score' the bevels lengthwise, close behind the apex, and possibly weaken or undercut the supporting geometry, leaving it somewhat more prone to folding over or chipping. Maybe not as severe, but this would approach or emulate the sort of damage seen in micrographs of edges sharpened on conventional scissor-edged carbide 'V' pull-through sharpeners, on which lengthy rectangular sections of the edge can be seen chipped out, folded or dangling.
On finer & polishing hones, I'd think a parallel stroke shouldn't do as much harm, if any, if there aren't any deep scratches being formed parallel to and just behind the apex of the edge. I have occasionally used a Fine/UF ceramic hone or hard black Arkansas stone, with a parallel stroke, to clean up burrs or re-align an edge, and it can work pretty well for that.
David
David
