David Martin
Moderator
- Apr 7, 2008
Are you speaking of the ones with a 1/2" arbor hole? As the other disc need to be glued to a backing in order to use for lapping? DMI use an 8" diamond disk from Kingley North for lapping now. The one I am currently using is 180 mesh, I'll get a 100 mesh if I ever buy a replacement - there is a wide range of grit size available. These cost about $50-60, about half of that if you only get the top plate and glue it to something flat. Made for rotary polishers, just drop a rag in the sink, set it on top and run a trickle of water while manual lapping.
They are no good for sharpening until you get to about 1200 mesh or finer, but the diamond bond is plated extremely strong and these things last. I have lapped/flattened a Spyderco fine, several India stones, Crystalon stones, Arkansas, and also polished facets on solid quartz and a number of other semi-precious stones and this particular lap is just starting to slow down. Plus, being round it has a lot of surface area.
