I am extremely happy with my sharpmaker. The diamond hones make reprofiling a breeze.
I do have a question though, would a relief bevel work the same? for instance with the sharpmaker they recommend a 40 degree edge with a 30 degree back bevel.
I've been using this one lately, I love the results
That's when you run into that powdercoat at the 30* setting. I's a Bear to remove and either takes a lot of pressure or a million strokes to get through it, removing expensive diamond chips frorm your rods.
If I reprofiled another of my coated RAT knives (which I won't) I'd lean my sharpening stone against the Sharpmaker diamond rods (they're the tightest fit) and then go at it with that rougher "stone" first. Save a lot of time and save your diamond rods too....just sayin..![]()
Results of what a black sheath??
sharpening rod that come with the sheath
borommokot- do you think a back bevel would be any less effective than convexing?
That one comes w/o the steel if you read the fine print.
I found that little sharpening steel here! http://www.knivesplus.com/VN-30403-Victorinox.HTML
It looks extremely fine grained and I may be ordering one for my toothy grinds I've been getting on Benchmade folders, worth a try I figure.![]()
