Sharpening recurve on KMG???
Erin Burke
KnifeMaker...ish
Hi all...
I typically sharpen my knives on the flat platen of my grinder. This has worked great for me. My current project is a small recurve, however, and I have to come up with another method for grinding the final edge. In the past, I have removed the platen from my KMG and slack-ground a convex edge. This does work, but I have had issues messing up the grind on the blade-tip as it comes off the slack belt. If all else fails though, I will likely try splitting a belt and slack-grinding the edge... but I was hoping somebody out there had a trick for grinding the final edge on a recurve.
Thanks in advance.
Erin
Phillip Patton posted a convex platen attachment that looked pretty slick. You might try searching for that post. I'm lazy, I know.
I like to take the platton off of my flat platton attachment, so it is a slack belt attachment, then I sharpen my recurves on a J-flex belts to get in the curves!!!
Just how I do it!!!
