I use the Buck EdgeTek Ultra. Three diamond grits (you’ll NEVER use the roughest, so two, really), and it’s a rod so it also handles anything with a recurve or a belly like the 104 Compadres.
As mentioned by others above, you need something harder than the Vanadium carbides in the S30V - in other words diamonds. Softer materials may dislodge the carbides and make you think you’re making sharpening progress, but you’re not - you’re just producing an edge of matrix metal with craters where the carbides used to be. Also the reason to go LIGHTLY on the diamond rods. You want the diamond to shape the carbides, not dislodge them. This is why S30V got it’s reputation for “taking a mediocre edge and holding it forever” because when it came out and folks only had traditional stones and ceramic rods, they couldn’t really sharpen it.
Lastly, don’t reprofile and thin the edge with a shallower angle. S30V needs more metal behind the apex to hold the carbides in place. You’ll never be successful if you reprofile an S30V blade to look like a 425M 110 Folding Hunter blade. Stick with the factory geometry and you’ll be in good shape.
Lastly, if you want to strop after the diamond rod, get some low-micron compound to load up the leather with and polish the carbides. Otherwise, you’re just spinning your wheels and polishing the matrix metal.
