I've seen Ben Dale of EdgePro demonstrating this technique. I think I've heard it somewhere else too. But it seems backwards doesn't it? A serrated blade like a Spyderco is essentially a single bevel blade. The back is flat and the front has a scalloped pattern. On a plain edge single bevel blade, you sharpen the front until you get a burr on the back and then remove the burr with the blade flat or nearly flat to the abrasive, presumably so that you leave the back as flat as possible.
How does this jibe with serrations then if you're supposed to start with the back? Do you grind it flat? Just a hair up (like 5 degrees or so)? Or all the way up at 20 degrees (for a sharpmaker on the 40 degree setting)?
More importantly *why* is starting with the back of the blade "the right thing to do"? I'm going to guess that doing it that way removes some extra metal from the back, and in fact forms a small microbevel there also. I'm going to guess that the rationale is that doing it this way removes less metal from the front and therefore has less tendency to grind off the points of the serrations and/or change the overall geometry of the serrated scallops. How close am I?
Thanks,
Brian.
