America has reached 250 years, and I am grateful to be here, in the best country in the world. Thank every one of you who helps make this country a better place, those who have gone before and risked it all, and those who've paid the ultimate price to make the United States what we are today.
Just a quick question, What type of steel do your knives usually have?
IMO, no, you cannot use just a fine stone to maintain an edge. You would eventually get to the point where the stone would be simply too fine for the amount of metal that would need to be removed. It's not something you can just spend more time doing, you need a coarse or medium grit.
For just one stone I would rather have a coarse stone and strop as it's far more useful. The DMT Coarse and a balsa strop with 1 micron diamond would be my choice. I can produce some scary edges with these two items.
Nah, "coarse" was being used loosely. The average knife enthusiast has no need for a stone coarser than a 1k. The only exception comes when you sharpen very hard and/or wear resistant metals, a 320 or 500 stone becomes very handy.
It's why I like the SG500 and 2000, the 500 is smooth and acts like a strong 1000 stone while the 2k is still fast enough to remove a good mount of steel yet produce a nice level of refinement. It allows a lot of work to be done with minimal tools.
I'm a big fan of the Sharpmaker. Very rarely use a stone since I bought it.
Hi
i wanted to ask if its really necessary to have rough/fine/extra fine sharpening stones
what if you only use an extra fine sharpening stone?
i mean can you skip the rough/fine and just go straight to the extra fine sharpening stone?
because i want to buy only one sharpening stone (going for the extra fine one)
do you REALLY need the other ones?
thank you in advance
hi i wanted to ask if the DMT sharpening stones with green color will give you a polished edge on your knife
howmany xxxx-grid you need to get for a polished edge?
edit: will the DMT Dia sharp (green version) give me a polished edge? green = 9 micron, 1200 mesh
Not polished with that one. However, if you use some 3µ & 1µ diamond stropping compound on wood strops (balsa, basswood, etc.) AFTER the green DMT, you'll bring up a polish very quickly. The 3µ Dia-Paste from DMT brings up a polish very fast, used as such. The green DMT hone will do a pretty good job 'prepping' the bevels for polishing, itself leaving a very fine satin finish. This assumes the scratch pattern on the bevels is ONLY left from the green (EF) DMT, and no coarser scratches are leftover from earlier grits.
You could also throw in the EEF DMT (tan; 3µ/8000 mesh) after the green; but the green should leave you close enough that you might not really need the EEF before stropping with diamond on wood. The EEF used after the EF can get the finish to a 'hazy mirror' on most steels, before stropping.
Depending on the steel, other less expensive compounds like white rouge, or Flitz or Simichrome polish, or Mother's Mag polish on hard strops can also bring up a polish very fast on less wear-resistant steels (1095/420/440/etc., and even up to D2, for example), also used AFTER the green DMT. Diamond compounds work especially well on high-wear steels like S30V, with their very hard vanadium carbides (which may remain 'hazy' with less-hard stropping compounds).
David
