What knife is that ? Just curious
I can't help having a guess; it's tricky from that angle but I think it's a Nuclear MOASH... am I right, erto?
As to the sharpening, I would just steel it (or ceramic rod) and hold off the grinding until it really needs it. Infi responds remarkably well to that.
If you aren't going to use it and just want the edge perfect, any system. I use Edge Pro when I want to reset a flat bevel.
Actually I am bit hesitant to touch or not. But you hit the target with your guessIt's a Tiger hide NMoash . You can tell by the enormous slabs of machined TH micarta. Leave it alone unless you're going to use it. If it's a safe queen leave it alone. Just my .02
My guess is it's like the top one View attachment 722695
I was searching for Worksharp KO and probably I will end up buying it.I use the Russian TSProf sharpener for most and my Worksharp KO for others.
Agreed. If it is a safe queen how did it get chips? I say use the hell out of it now.Freehand it out and then flog it thru some hard timber. Put it away dirty. Make that knife yours.
