I use the mousepad and green chromium-loaded leather glued to a flat piece of wood.
I've used the mousepad method with success on Bark River knives. I've also successfully used the mousepad with other convex knives, such as Opinels, as well as flat and hollow ground knives, such as a Spyderco Calypso, Jr. and a Buck 110. All of these knives were hair-popping, newsprint push-cutting sharp after sharpening with wet and dry on a mousepad, followed by stropping on chromium-loaded leather. So the mousepad works well for me, at least.
Just this weekend I touched up my Mini-Canadian on 2000 grit wet and dry on a mouseopad followed by stropping after I had used it to whittle Basswood.
I think one possible difference between the mousepad and a firmer surface would be that with the mousepad, you're actually grinding the side of the blade all the way to the spine. I don't know whether a firmer surface gives would give the same wrap-around effect as the mousepad.
I'm sure using leather works fine too -- I've convexed an edge with wet and dry on bare wood. I'll have to try wet and dry over leather to see if I get even better results.
