For field expedient sharpening I use a two sided Norton on severely dull knives to set an angle. Then I use sharpening sticks for want of a better term.
Sharpening sticks are about 1x1, 2x4, etc. I either glue or use the rubber that already had adhesive on the back on the 1-2 opposite sides. On one side use rubber cement with various grits paper to your satisfaction. On the other side epoxy a strip of leather and load with compound. Ive used automotive rubbing, auto polishing, Flitz, Brasso, etc. using a little kerosene or JP to help certain compounds permeate the leather. A 90-95% solution to the sharpening problem.
The CS Kukri (I have my 2nd) the handle doesnt last. It doesnt take Deet or other POL products well and other wise melts. It abrades quickly and wrapping it w/para cord is only a partial solution. Not nearly as impervious as wood, horn, micarta or steel (Project 1). The edge itself as Cliff points out is a hollow grind. Works good in some situations but not others. The sheath actually works out real well strapped to a pack, in my spare time J Ill try and get functional equivalents for my HI Khukris.
On the overall hardness a number of Marines could use the ones with harder points. Less abrasion when using the points to undo metal strapping or digging.
S/F, Mike
