- Feb 19, 2006
Have you tried marking the blade with a sharpie? It will help you see what is actually contacting the sandpaper. A tip I got from Lennox that I found useful was to mark the edge with several lines perpendicular to the edge instead of just coloring the whole edge.
This is one of the most important tips for a newbie, or even old oldie. By 'painting' the entire edge with a black marker, then making a few passes on your sharpening device, you can then examine the edge (a loupe or maginfier of some sort is helpful) to see where exactly you are removing the metal. Adjust your angle accordingly. Many Busse blades come from the factory with a rather steep edge grind, so you will probably have to raise up the back of the blade to hit the mousepad at a steeper angle to work the actual edge. If you intend to change the edge angle and make it shallower, say, 20* per side instead of 30*, then 2000 grit is way too fine.
IMHO, a mousepad is too soft of a base. Unless you use very light down pressure, the blade is going to sink into the pad, the paper will 'wrap' around the edge, and it will just dull the edge. Use a firmer base, such as a piece of leather, or even a thick magazine or catalog.
INFI is not a supersteel that is hard to sharpen. Go over to the Maintenance subforum, there are about a million threads on diffwerent sharpening techniques.
