- Jul 10, 2009
She's a beauty. But I'm guessing rust is an issue with that type of finish.
Well it is a satin finish done on my belt grinder, not a porous bead blasted one, but sr77 rusts like crazy when not protected.
I just want to know how ban does that sand blasted satin look, I drool every time I see it.
Jim, I agree. I don't really think we can get any sharper unless the edges were chipped away atom by atom with a laser.
I just managed to get my Lionsteel SR-1 to pop, whittle, split, and tree-top(not sure if one or more or those are the same) my leg hairs. It does take a few tries, but I turned the edge up, put it under my hair(on my head, which is getting pretty long), and popped quite a few of them into the sinkI put a little extra something, something on that bad boy for you before I sent it back. :thumbup:
Hmm, seems like I still have a lot of practice to do thenHow do you like that worksharp? Seems like a good little gadget if you want a belt sander convex edge without having to worry about holding the knife even. You should be hair popping at 1200, at 1 micron you should be hair splitting and at .25 micron you should be able to cut by just barely touching.
So who do you think is making the sharpest edges these days?
FIB (focused ion beam) machining has been used for at least a decade for making STEM (scanning tunneling electron microscope) probes. Doing a knife on one might be asking a bit much though.
from the factory i go with spydie. from members: ankerson, knifenut1013, so-lo, & unit.
dennis
Hmm, seems like I still have a lot of practice to do then. I can barely get hair to whittle after the 0.5 Micron strop.
Still confused about shaving sharp and hair popping sharp. When I run the blade along my leg, it's not like I have a lot of hairs popping off all along the way. Maybe just one hair per two passes. Though I can "feel" the edge scraping along the hairs, and I do end up having some (skin?) gather up along the edge and some small bits of hair.You might be jumping ahead too fast. I can shave arm hair (albeit, roughly) in the 200+ grit range if I knock off the burr.
That blade amazes me unit .. It's incredible. I can only imagine how much time you have in it ... :thumbup:
At 1 micron if done right you should have an edge sharper than you can imagine. Wittling hairs and being downright scary. At .25 we're well beyond the realm of useful and just showing off, but it is fun to do.
