Thanks for this information! I have an old Village Blacksmith corn knife that I bought at a farm auction in 1977, been wondering where it came from ever since!Mine is an old “Village Blacksmith” 6” butcher knife (although half of it has been sharpened away, so I use it more often for boning). Bought rusty at a swap meet about 5 yrs ago, cleaned and reprofiled it soon after. Made by Washington Cutlery Co. of Watertown, WI - I believe it dates between 1906 and 1920. Steel type unknown, but certainly a simple alloy.
I sharpen it using old methods: coarse oilstone, fine oilstone, then leather strop if I’m in the shop or smooth steel if I’m in the kitchen. Either way, takes a nice keen edge and sticks on my fingernail like it was glued there.
Parker
Cheers, kind of you to say so; means a lot coming from a professional too.Strong Work, I like the finish those matrix stones make, very bright and consistent on Maxamet yet don't overpolish the apex.
Beautiful job, not something seen very often.
Thanks for sharing
Lol that's obserd! What's the steel? What sharpening approach did you use?
Sometimes I finish on .5 micron. It's nice how it just slips into everything.Simple carbon steel Japanese kitchen knifes can get into the straight razor type of sharp pretty easily, usually off a translucent ark. So will the AS steel knifes if I put a coticule in front of the translucent. It’s overkill but why not make fixing dinner fun every once in awhile?
How long will that edge last with Maxamet?Here you go sir:
PXL_20210710_050535859.MP by Martin Johnson, on Flickr
It was difficult to get a good shot through the loupe on 60x using my phone, hopefully this gives an indication of how clean the edge is:
PXL_20210710_050422280.MP by Martin Johnson, on Flickr
I didn't notice until I'd put the picture onto my PC, but the blade is so reflective it shows the pixel lines / flaws from the image printed on the calendar I'm holding it above:
PXL_20210710_045911640.MP by Martin Johnson, on Flickr
One more for luck:
PXL_20210710_045931514.MP by Martin Johnson, on Flickr
I've tried this finish (down to 0.1 microns) on S110v, s90v, s30v, CTS xhp and Maxamet (all paramilitary 2 / para 3s) and IME they all lose the 'sticky sharp' / 'hair whittling' killer edges fast.How long will that edge last with Maxamet?
Thanks for the response. How do you maintain and bring the edge back? Do you just use the strops?I've tried this finish (down to 0.1 microns) on S110v, s90v, s30v, CTS xhp and Maxamet (all paramilitary 2 / para 3s) and IME they all lose the 'sticky sharp' / 'hair whittling' killer edges fast.
If you plotted this performance out on a graph you'd lose the first 25% rapidly and then it slows down (of course at different rates for the respective steels). Maxamet seems to hold its edge the best which is no surprise.
They all stay sharp enough for my needs - which is nothing too heavy / extreme.
The para 3 in Maxamet is the only I one took down to 10 degrees a side though and you can feel the difference this angle makes - it's remarkable.
I am using , a 600 diamond, then white formax on a strop, it was pretty dang sharp, then I lightly ran 5 strokes on a basswood spray with .5 micron diamond, it’s cutting toilet paper and paper towel sharpThanks for the response. How do you maintain and bring the edge back? Do you just use the strops?
I have a Para 3 and Sage 1 in Maxamet. The p3 I took to 1500 kme diamond and stropped and the edge is OK but the bite leaves pretty quick. I'm starting to just mess with low grit stones and strops and like the results so far.
Wot S S-3 ranch said; diamond strops finished by bare leather, all on my edgepro and I'm back to laser beam in no time! What really helps me is the angle cube here just to keep stropping tolerances tight and consistent- it makes a tangible difference.Thanks for the response. How do you maintain and bring the edge back? Do you just use the strops?
Right now I'm finishing with 300 grit diamond and then a 1.5 micron strop. This gives an edge that will still easily shave but the bite stays for a lot longer. I have some really rough stropping compound coming to me though that I'm wanting to try out.Wot S S-3 ranch said; diamond strops finished by bare leather, all on my edgepro and I'm back to laser beam in no time! What really helps me is the angle cube here just to keep stropping tolerances tight and consistent- it makes a tangible difference.
I tried my pm2 with a 600 grit finish but preferred the polished edge. It's weird though, I do feel like I should have one 'low grit' finished user. What do you take yours down to? What grit do you strop with to maintain the edge?
That Shosui Takeda looks interesting. Where did you get it?Yeah. My 4 sharpest are from Japan. Here they are in order of sharpness:
I use this razor once or twice a week to scrape off my neck beard. Haven’t used a disposable razor for over a year now. Unknown steel, but probably white as it’s an old blade and I believe white was more common in razors. View attachment 1597643The Cold Steel lives attached to my headboard behind my mattress. San Mai III in VG1 sharpened to a very acute angle. I got a hard one. It will whittle hair.
The small cord wrapped knife is made by Shosui Takeda - one of my favorite makers. It stays close to hair-whittling sharp AFTER CARVING WOOD. Crazy, “scandi-vex-style” geometry in Aogami Super Blue.
Last one is white steel and I have the maker’s name but not at my fingertips. (I’ll find it if anyone wants to know). Being chisel ground, fine grained, and hard, it’s easy to keep around hair-popping sharp, even with fairly regular use.
Nice collection of Kamisori!That Shosui Takeda looks interesting. Where did you get it?
