- Nov 25, 1999
Architect,
I didnt have in my mind belt grinder at all. I sharpen my (and others) convex edges free hand using DMT Duo-Sharp double-sided (coarse/fine) 8-inche plate and finishing with the set of SPYDERCO ProFiles.
Creating convex edge I tend to shape it at about 45-50 degrees at very-very edge lowering sharpening angle pretty rapidly behind it. In my honest opinion additional edge strength obtained this way is the only reason to go with convex edge at all.
If you are going to sharpen very edge at Sharpmakers preset 40 degrees just create decent back bevel at 30 degrees and come on with additional effort making full-program convex edge! Anyway it will be more than enough convex by nature because nobody can hold strictly consistent blade position even using Sharpmaker.
Working with the Sharpmaker the most important is to be sure that the very-edge sharpening angle matches Sharpmakers preset one. Differently you should reprofile your edge to let it match. Depending on actual sharpening angle this might take a lot of time and effort (significantly less with the set of additional set of diamond rods).
Anyway, the method recommended by Sharpmakers manual is not too good for first sharpening (reprofiling) session. FAQ recommended burr method looks way preferable for me.
