- Sep 19, 2001
Maybe I read it wrong, but I thought I saw this somewhere. Since the ink soaks into the paper, doesn't seem likely. I just tried it with a half dozen knives, with the underside of a diasharp sharpener placed under the newsprint for support. I can't get just ink, but I can slice off a layer of paper with my sharper blades (not that I think any of my knives have great edges) But I can also get a layer scraped off with a dull edge, or even a crisp blade spine. I tried to see something to differentiate performance, but I don't know if this 'test' has any value anyway.
I noticed my 'sharp' knives began the cut cleanly; I cut into colored sections, and there was a straight line where I began. The spot of paper where layers were cut by the duller knives looked more like they had been lightly abraded away, not defined by a crisp line. Almost every cut ended up going through the entire sheet after about a 1/4" of shaving. I only got a few small chips, and one larger one, about 1/2 square, without cutting all the way through the thickness of the page. This is probably heavily affected by the angle of the bevel, as much as the level of sharpness. It also took a few tries with each knife before I could start to cut into the paper instead of through it immediately.
For removing ink without slicing off a layer of paper, holding the blade perpendicular to the surface and scraping would do that. You don't need a very sharp knife for that, maybe I misunderstood what is supposed to be donwe with the newsprint.
And none of my knives push cut the edge of the paper worth a crap, had to be 2" or less away from where I held the page.
