sheath mounted psk
I have a condura sheath for a folder, that I want to mount on my f-1 sheat that Normark made so I can have a kit with me right now it consist of a brunton type 7 lensatic compass, a whistle a sewing kit cinsistin of a small spool of thread and 3 asst needles a small led, a small ss pill case with som pj soaked cotton inside, 1 bsa hotspark, 8 safety pins, 1 credit card sized magnifying glass (plastic)1 credit card sized eze-lap 600 grit diamond stone, 1 small fishing kit 3 small hooks 20 ft of 6lb test line asst spit shot 1 small spinner, 1 small gummi worm lure 2 small bobbins, 4 micropur tablets. this is to complement my usual dayhike gear whcih would be my f-1 my vic sak fieldmaster, a can of capsicum pepper spray, a nalgene holstered in a ss cup which his hung by a lanyard made of 30 ft of 7 strand paracord, and a fak....any other ideas for the kit, or the gear are welcome... Iknow I'm leaving stuff out.
That's really cool!!!! romm enough for everything in there...Mine is much smaller, I try to stay below the radar as much as possible. but I really like that setup.
My first impression is a fanny pack. After building a few sheath-mounted PSK's I've come to the conclusion that something the size of a single M16 magazine pouch is about it. Past that, the weight and bulk starts to get out of hand.
Robert's solution is better than anything I have cooked up, but I'd pass on having something strapped to my leg. I'd go with a fanny pack, a mini-BOB in my main pack, or a hydration pack with PSK for day hiking.
It's new. I also have a "mini" version that takes smaller pouches, and a Molle only version that allows a variety of pouches, or none at all, depending on what you're doing. Here's a side shot.
That is the best thing I've heard in a while. You've sparked some interest Dale. :thumbup:
There are all kinds of small hydration packs, so you can fit your size needs and budget. You are going to want water if you are hiking anyway, so you're going to be carrying some sort of container. I like hydration systems as you can sip as you go, helping me to drink enough water. Now that you have a container strapped to your back, you have a perfect place to haul your snacks, extra clothing layers, and your PSK. I have a Platypus Mega model pack that has a 2 liter bladder and about 450 cubic inches of storage inside with a "beavertail" flap on the outside that can handle a fleece or a raincoat. I can put an Adventure Medical bivy bag and a good sized PSK kit inside, along with lunch.
You can take it as far as you want, with the large CamelBack rigs crossing the line into full blown backpacks and eveything in between. They look totally sheeple too, so you can walk a city street or a trail with one and not look a bit out of place. If you want more storage space, most of the newer daypacks are hydration ready, so you can toss a bladder in and build your BOB around it. I like the smaller, simpler rigs to keep the weight down and the challenge of seeing what I can get of of the most compact lightweight rig.
As far as gear in the kit goes, I say "get out and use it". Shortcomings will make themselves known. My kit has evolved quite a bit over time.The kit you've got is a good start. Personally, I've swapped out the magnifier for a mini bic lighter - thousands of fires quickly and reliably. Instead of pj&cotton balls, I use cotton dryer lint soaked in melted paraffin wax. The fibers are smaller and seem easier to light. For snares, I find guitar strings work best, especially if you thread a treble hook onto the loop and make a squirrel pole.
Sometimes I go out solo and chuck my ruck under a tree in case I need it. Then I live out of my kit. The other thing is that different terrains and climates require different techniques. My west coast rainforest (where I live) kit will be understandably different from that of someone in the desert. I would rather adjust my kit as I travel than carry items that aren't geographically appropriate. I agree wholeheartedly with Dale's thoughts on a sheath-mounted kit. I tried that with my leg mounted Gerber and found it was always hanging up and making noise (bad for bowhunting!) Currently, I use a tool wrap meant to go under the seat rails of a mountain bike. Packed size is 2 1/2" X 4 1/2" and it weighs about the same as an orange.
I like the idea of having the basics with my knife...
Ergo:
Pitchwood, metal match, sharpener, 550 cord, zip ties, repair kit, etc.
My tendency is to layer gear; on-person/ in pockets, knife w/ sheath,
radio harness, on up to backpack.
Whatever works real-world for you...!
Cheers,
8
I stuffed a few handy items in an Altoids tin and stuffed that into the pouch of my Becker sheath.
Of course, I hardly ever take my Becker out, so a fat lot of good that did.:grumpy:
Plan B is to get a small pot with a tight lid for a kit container, make a more substantial kit and then carry that in a GI canteen cover.
Hey Guys..
RescueRiley...
What if you took like a nylong pouch from a Leatherman or something similar and zip tied it around the sheath ?
I'd put one in behind the belt loop and one just below the belt loop...
You can get some pretty Hefty Zip ties that will hold that sucker in place...
That's what I would do..
Robert H...
That's Awesome..I really like that set up....
I'd be interested in the small one myself...
Can I buy those from you individually ??
How is it mounted ??
ttyle
Eric
O/ST
i found that camera cases are made out of different material and range in size and color at target/walmart and look at them as PSK instead of camera cases and you'll find the right size and mount to my belt close to my knife or a small one to attach to your knife sheath and holds your BASICS, Just a thought, remember a PSK is simple,K.I.S.S. "keep it simple stupid" to much gets heavy quickly , so keep it simple !
My psk's have gone through many changes over the years. Like everybody I try to take as little as possible. KISS. I went through a hightec phase and found I began to add rather than eliminate non-essentials. (mainly because of all the cool gadgets out there) So I changed direction and went toward the primitive route. While I don't think you should skimp on a good first aid kit... I feel that what you think you need and what you really need are two totally different things. There are cases of people being lost for weeks, with no gear and no wilderness skills and still coming out alive... while other times the rescue teams find a hunter dead sitting next to his fully stocked pack. People die of shame not lack of a PSK. Its what you have inside you that determines the outcome. Replacing some gear with knowledge (weighs less) is often the best thing you can do for yourself. Learn to look to your surroundings for what you need... its really quite liberating. I'm still learning how to do this. Here are a few kits I've used when in the bush.
My old pouch (never left my side)... leatherman, needle/sinew, firesteel, jute, flashlight and sand paper.
My new pouch (never leaves my side)... flint, tinder fungus, aluminum foil, fatwood and flint striker
My bushbag (take on day hikes and over-nighters)... shoulder bag, poncho, compass, firesteel, SAK camper, cordage (jute, leather thong, paracord, decoy line), energy bars, canteen/cup combo.
That's funny, Foilist. I've often planned on using an Altoids tin for a psk but the round shape always seems to waste space.
Not trying to hijack but texastony, I see that LMF II in your avatar...you like ? I have a "Mk I"
Magnussen, we're of like mind: "Keep it small, keep it simple, but keep it on you..."
I've found local native bands trying to keep the 'old ways' alive are an amazing source of local knowledge.
don't worry about hijack,man i love that knife,,compact,can do a lot of chores and the sheath is great ,built in sharpener and has the ability to mount a smaller sheath to it to carry other items,and the butt cap is a excellent self defense tool, if needed, i would recomend getting one,i prefer it over the older Gerber bmf / lmf , I own the tan one right now but plan on getting the gren version and i am undecided on the black version at this time. it the next coming days, i have two older Gerbers i may sell to aquiRe the green lmf ll , older Gerber boot knife and the guarding back up...Thanks TD
That made me laugh about your Becker but everyone could learn from this !
Everyone on this Forum has some great kit but it's not worth a damn if you don't have it with you when Sh*t happens !!!
I think Riley must be of the same mind. I see people on here posting pics saying here is my PSK and they have a knife with a 10" blade, an Axe, Billy can......all great stuff if you are camping or getting your Mrs to carry it but I hike regularly and there is no way I could lug all that stuff around.
If you have a sturdy fixed blade in the 4-5" range, some cordage and a means to start a fire then you have most bases covered and you are more likely to have it with you when you need it !!!!:thumbup:
I agree with pitdog ,my PSK , i keep in my vehichle on a daily basis , does you no good at home and that "just in case" happens !
