Shifting pivot on Chaparral
Hi! I am pretty new to this subforum so thanks in advance for your help. I don't own many Spydercos but I recently picked up a mint condition Chaparral in Carbon Fiber. I was the third owner, with the first one carrying it and the second owner flipping it. The knife looks and works great but I noticed something peculiar. The pivot that the blade rotates on shifts within the scales. If I pinch both sides between my index and thumb, I can move it up and down, perpendicular to the scales.
When the blade is deployed there is no blade play. When it's closed, the blade is centered but I can move the tip up and down if I pinch the spine with my fingers.
Is this normal? It kind of bothers me because it doesn't "feel" normal but I am not knowledgeable enough to say why it's wrong of if this is broken. Is this some special pivot design by Spyderco?
I asked the first owner and he said he never noticed it and suggested the second owner may have taken the knife apart and perhaps broken some threadlocker on there. I asked the second owner and he denies any such thing.
Any help or insight would be appreciated.
^^^ worth a try cause that's a simple solution...
however, the Chap is engineered with very tight tolerances and so even with a loose pivot you shouldn't be seeing that kind of slop, IMHO.
almost sounds like you have a W&R issue...can you be certain the former owner<s> didn't disassemble the knife and monkey around with it?
When open the lock will keep the blade from moving even if you have a screw loose or a washer missing.
Hi everyone, thanks for your help. I checked last night and the pivot is as tight as can be. To make sure I don't have some strange free spinning one, I tried loosening it briefly and it unscrewed just fine. I only did a quarter turn then tightened again. I also held a torx on both sides to tighten. I cannot be certain the previous owner didn't dissemble it. He claims he did not and at this point it's such a weird problem (and it was a Reddit transaction), I really feel I couldn't "file a claim" with him. Is this something Spyderco warranty/support could help with? I can also take it apart and see if I am missing anything? I would either have to post pictures for you guys to check or maybe I can look at disassembly videos or pictures if I can find any. Thanks.
The screw could be bottoming out. You could grind down the shank so that it can be fastened tighter.
This could be it. When I took my Kapara apart to grit blast the clip and screws I noticed that the screw that retains the clip was slightly longer. So, if the longer screw got swapped to the pivot, it could be bottoming out as kniferbro mentioned. I don’t know if the Chap is put together the same way but it might be worth checking out if you suspect the knife has been taken apart.
