Thanks for that info. Would this impact the Quantum as much? It has stainless bearing race inserts. I'm not sure if those are less likely to be dented by the ceramic than the titanium bearing races in other models.
The F3ns and F95 both use stainless steel washers vs titanium. The Hation zero I have uses TI races via the scale though.
But, to answer your question. It does go for the quantum as well. If it would dent M390(which is the most important part, washers/races are replaceable), it'll definitely dent hardened steel braces. Ceramic is at 95-96hrc. M390 is around 60-61hrc, the hardered metal washers maybe at 60 hrc.
The oem stainless steel bearings maybe 54-56hrc probably. Most are in the mid-high 40's.
Especially the cheap metal ones on Amazon.
Something you can do that helps me with reassembly is put a little
thin line or smallish dot at the top of both pivot screws(12 o clock) with permanent marker when assembled(it will wipe off easy, so take to not). When reassembling, turn the main pivot so the line is at top again(12 o clock). When tightening the screw down, turn until it matches that opposite side again(both at 12 o clock). Then you know you didn't over tighten and that the pivot is tightened exactly where it was before disassembly. It's pretty hard to screw up the marker method. Unless your trying to hurry. When messing with $1k+ knives, you shouldnt be hurrying.
The marker comes off with alcohol normally pretty easy. If not after a day it'll wear off. I guess I should have put that in above, but I forgot and that post was getting pretty long.
Most knives come with ceramic bearings now a days. So I use the marker method now when retightening all of them. Pretty much always... For shiro's, normally a thumb nail will work. Max tightness with a thumb nail is normally just right after where blade play stops. Unless you have ridiculously strong or just thin thumb nails.
