Hi Mike.
I have a couple of suggestions if you don't mind trying them.
1st. I bought a cheap EZE Lap at the local Wal-mart. Cliff says the DMT hones are much better,I agree and I am going to get me a couple of them later along with the Ceramic steel.
Anyway,this thing was cheap and handy. I broke it in on an old knife first because they cut really fast and rough when new.
I layed it on the edge and raised it up just so it wouldn't scratch the whole edge. I then rubbed it along the blade,careful to watch the fingers. It gradually cut into where it was about 1/16th to 3/32nds wide along that side and there was a burr all along the opposite side the whole length of the blade.
I then layed it on the other side and did it the same way. It didn't get quite as wide on this side before the burr came up all along the other side.
I then used the hone on one side and then the other with very light strokes to remove the burr. When I could no longer feel a burr on each side I put it on my fine ceramic sticks and "viola" I had that scary edge everyone talks about. It sliced paper easily and I finally got enough courage to try shaving with it along my arm. ( My skin is very thin from one of the meds I take.
) It literally popped the hair off.
I find it also chops a lot better now than it did when new for some reason.
2nd. If the soak doesn't work to tighten your scabbard you can do this. I did it to the 15" AK scabbard because it was a little loose here in Oklahoma where there is usually a lot of humidity.
I have a bunch of scrap leather left from old projects. I cut a piece of thin leather about 1/2" wide and 2" long and very carefully with some of the gel type super glue already on it used a pair of tweezers to place it exactly where I wanted it.
I then took a pencil and pressed it down and it was there. I had to trim it a little with a sharp wood chisel because it was a tad too thick. It worked well.I also put another piece on the other side. I tried the regular super glue and it didn't work and used some Weldbond ® I had. It took a little longer to dry.
If you should do this make sure that you haven't oiled the scabbard inside and give it ample drying time. I had to dig the 2nd. piece out of the bottom because I got in a hurry and that wasn't much fun!
I hope this helps you out. I used to be able to get a knife sharp,but it always took me a while. Since I have been reading here there is no longer
any problem with getting a nice sharp edge quickly. I have found paying attention to the angle was the key for me.
>>>>---¥vsa---->®
