Thanks for the tip and reminder!! I don't grind mag but water seems to put ti fires out just fine... It all goes into a big 10-12" cone that goes through a 5" opening into a water bucket and haven't had any issues so far. I only turn the vacuum on if I'm grinding wood/micarta/g10 etc.
Class ”D” fires are burning alkaline metals. Various dry powders are used to extinguish. Smother the fire & draw heat out.
Fwiw, if one believes the press, Magnesium disaster OP mentioned was caused by the buildings sprinkler system wetting molten magnesium. The Fire Brigade did nothing but deal with aftermath. Further, the plant safety seems dodgy based on various violations in recent times.
Dang, I had no idea this was true. I've only got an ABC fire extinguisher in my shop. Anybody have a recommendation on an affordable place to buy a Class D extinguisher? A quick Google search shows that they're quite expensive...
They are expensive. How about a 5 gallon bucket filled with dry sand ?Anybody have a recommendation on an affordable place to buy a Class D extinguisher? A quick Google search shows that they're quite expensive...
Dumping sand on it is just fine if burning material is a surface what can be smothered over. Extinguishers designed this job, their powder is designed to stick to hot metal to assist smothering & absorb heat.They are expensive. How about a 5 gallon bucket filled with dry sand ?
I don't work with Ti.
I have a medium sized CO2 extinguisher that should displace most of the oxygen in my shop as I exit. I also have a compressed air/water extinguisher on the other side, and water buckets at each grinder.
Another reason to use steel instead.
I’ll never believe your lies about steel!You can start that on fire too. We had one of our chip dumpsters start in fire once. Figure it was a combination of fines and something smoldering from the burn table. That was exciting. Fire department said we're just here to protect the building, so I drug it away with the end loader and let it burn.
My recent scare was pulling my garden tractor into the shop to weld on a new muffler. I draped my leather apron under where I was welding but it wasn't sufficient. Leaking oil/diesel + dry grass packed into everything + welding = oh hell where did I put that extinguisher???
