- Dec 24, 2014
I had a few questions so instead of hogging the forum with multiple threads I'll do them both here.
1st thing. I started building knives late last winter. As a matter of fact I bought my 1x30 grinder just after New Years. Now that I have my 2x72 Variable speed Grinder w/ VFD, electric oven, and other cool toys, I need to figure out how to heat my shop. Its only a 12' x 18' or so area.
My main priority, is to have a wood stove. Its easy, and its cheap. My work has scrap ashwood every single day so, material to burn is not a problem. But obviously I cannot run a wood stove 24/7.
I'm worried about my equipment, and product, that may be affected by the cold.
Epoxies, oils, digital controls, all of that sitting there in possible below zero weather sometimes (Upper Michigan
) Will it be ok until I'm done with work and am able to heat it up, or do I need to find a permanent heat solution?
2nd question
I finally am going to HT my first blade in my oven. It was finished yesterday, just need to add some thermal paste to the heat sink, now its fully ready. I was just going to throw a 1084 blade in there to start. Has a 7" blade so it would be slightly too big to HT in my small forge anyways. But my question is, I understand 1084 HT, but how do I know the blade is up to temp in the oven and ready to quench?
Its easy when I'm holding the blade with a torch on it and can check with a magnet but, if I heat to 1500*, how long should I let it sit before I know the blade is at temp? Not sure I understand that fully. And also, should I put the blade in cold, and slowly heat up the oven?
Thanks in advance. Sorry for the long post.
2nd question
