Shop safety tips
Members here including Joe Talmadge and myself have agreed that there needs to be a sticky posted for shop safety. These include safety tips for buffers, grinders and other high speed equipment commonly used in knifemaker’s shops. I have asked several makers to join this group to submit safety tips, that will be reviewed before being posted in the sticky.
If you see something that is not covered, please submit it to me. Appropriate safety tips submitted will be copied and pasted into the thread, with the member’s name appearing at the top of their safety tip. Anyone having issues with any safety tip can post in another thread that will be linked to from this sticky. Anyone submitting information to me, please make sure to include your forum name in the subject line, along with your safety tip. I hope this thread will help keep someone from getting injured or killed.
Since a buffer seems to be considered the most dangerous equipment found in a knifemaking shop, here are a list of things to do or not to do with a buffer. I will be adding tips for other powered shop tools when I get a list made up.
1. Make sure you read and understand any instructions that come with a buffer before even using it.
2. Never wear long sleeve shirts around a buffer or anything that can get caught.
3. Always wear the proper safety equipment such as safety glasses and a leather or similar apron. If you wear an apron, make sure it can’t get caught by the buffer.
4. Make sure you have your buffer firmly attached or bolted down to your work bench and properly grounded. Don’t attach it to a stool or anything that could easily be tipped over.
5. Never go edge first into a buffing wheel, or any soft wheel that the edge can cut into. The blade will catch and get thrown back at you with explosive force. Stay alert and pay attention to where your work is at all times.
6. Use only wheels that have been manufactured and tested for use on a buffer. Never ever try to make your own buffing gear or buffs, as this is an accident waiting to happen. It can and will get you or someone else injured or killed.
7. If someone is watching or helping out in your shop, make sure they have the proper eye protection and safety gear too.
Safety Suggestion input from Members here include;
Esav;
“Never wear necklaces, bracelets or rings, and tie back long hair”.
Old Physics;
“Wearing gloves while buffing or grinding; If it were not for Kevlar gloves, I would have a lot of flat spots on my knuckles and finger tips, along with burn marks from the buffing wheel. When I used to run labs and work in labs, I made darn sure no flammables were anywhere near equipment like welders, buffers, and grinders. All it takes is one spark, or one hot cinder and you've got trouble. In fact, the flammables were in closed metal cabinets."
A C Richards;
"No safety instruction will replace common sense when using power equipment.
The biggest thing is; Pay attention and HAVE NO DISTRACTIONS. This can be the greatest cause of accidents on the buffer. Lose concentration for just an instant and it can be all over”.
Bufford;
“Do not buff when you are in a hurry, and pay attention to where your work is on the wheel at all times. Do not force the buffer, as this leads to loss of control, and do not buff or use any power equipment if you are in a bad mood or tired. Buffing is dirty, use a dust collection system, and a respirator if possible. Your lungs will thank you for it. Empty your dust collection system frequently, buffing dust is extremely flammable”.
goldsmithy has a good suggestion. put a foot switch on all of your equipment so if anything happens you can shut things down quicker than having to flip the switch. a foot switch can also make it easier if you have one on a disk or belt sander. you can position a blade where you want it and not have to move in order to turn the motor on. i plan on fixing up a foot switch i can plut anything in that i'm using at the time.
