blgoode
- Oct 3, 2003
Just wanted to show you guys what helped me really speed up. Using 36 grit belts to rough in my grinds. Got these roughed in in about 6 hrs total. Also used a worn out 60 grit to break the edge at a 45degree to my center scribe lines.
I'll use 60 grit to raise my grinds and get the edge thinner then heat treat. I always go back to 60 grit after heat treat and go from there.
My advice is get 36 grit and see if it helps you along
I also dont grind my D2 far up before heat treat because I plate quench and I use the stock thickness to hopefully keep the blades straight between the aluminium bars
