Nice tour good job on the disk you might want to look at mounting it vertically at least for me it really gives me more control.
Hey Tim, thanks. I did put a bit of thought into how I would orient the disc. It all came down to the idea that I like to be able to look down on the grinder from above to visually index my work piece against the disc. There are folk who swear by both ways. I've been using my 8" disc horizontally, and I'm comfortable with it... I figured I'd go with what I'm used to.
How do you control the sparks when you weld there ?
Count... I knew somebody was going to ask me that, and I'm afraid that I don't really have a great answer yet... at least not one that I'm 100% satisfied with
. If I have a large welding project (which is seldom), I'll roll the welder out and work outside. Most of my projects, however, involve smaller welds... so I just take as many precautions as immediately practical; things like sweeping up and vacuuming the immediate vicinity, moving the garbage can, and doing most of my welding work on Saturday mornings when I'll be around the house for the rest of the day (just in case a spark smolders into a flame). It seems like it would also be a good idea to screw some sort of steel backer to the wall behind the benchtop... I just haven't done it yet. I'm certainly willing to accept practical advice on how I can improve this area.
Thanks for the shop tour, but why tease me by mentioning the drum set and not showing it? A disc grinder will be the next thing I get for my tiny shop so I was intrigued by the Nielsen system.
Billy... I have a wife and a bunch of kids, so my drum set is a Roland TD-10 module with PD-125 and PD-100 heads, a VH-11 hihat, two CY-14 crashes and a CY-15R ride... and a set of headphones.
Rod's disc system is awesome... VERY professionally built. As I mentioned in the video, I was a little shaken by the price, but after seeing the system first hand consider it to be very reasonable. :thumbup:
Just an idea, I see the front of the cabinets are scorched at the KMG, why not put a piece of sheet metal hanging down in front of the cabinet at the KMG, to keep sparks from hitting the face of the wood cabinets and the counter top while you're grinding?
That's actually a really decent idea. Some of that black is definitely scorching... though a lot of it is just accumulated grinding grit. Occasionally I'll wipe it down with a damp towel that removes much of the discoloration. Nevertheless, additional protection is always a good idea. I'd definitely want to do it ins such a way as to not make it overly cumbersome to access the motor cabinet below. I'm sure that even a small barrier could help deflect the majority of sparks and grit. I appreciate the feedback.
Are you going to add a work rest to the new disc?
Maybe eventually. The 8" disc that attaches to my wood lathe has a decent adjustable work rest with t-slot and variable-angle guide. I really only use it for squaring-up and angling handle material... and it'll be around for those type of operations.
Whats next on your list of machinery?
I'm starting to run out of space Fred... I don't know how much more I can cram in here.
Maybe a small lathe... like
THIS ONE from Micro-Mark. I figure it could sit on the new bench next to the disc. {shrug} It would likely mean a steep learning curve and a bunch more tooling, but it could be useful for sure.
