Should I get a KA-BAR D2 Extreme or one made from 1095?
I posted a thread before about wanting a KA-BAR, but my choices were the D2 and Nextgen. Now, I have discovered rust is not a big issue in knives, and the 1095 versions of the KA-BAR are a very good, low priced knife and the 1095 steel is a very solid performer. Now, I'm sure people are probably sick of this question, but which one do you recommend? I have posted in previous threads that I am Australian and live in Australia, so if I go for a 1095 blade, it'll be one without USMC engraved on the side of it. This is just because I'm proud of being an Aussie, and don't want to seem like I'm trying to be an American by owning a USMC knife, and it just wouldn't be right. I don't even know anyone in the USMC, let alone any American people (maybe two or three). All I know is I want a KA-BAR, which will be used (not way too heavily but still used) and I want one because they're awesome. Now my questions are as follows:
1: I understand D2 steel (in theory) is much more brittle than 1095. Can anyone say this is true, because I can't find any evidence of it being as brittle as some claim. I have found evidence it is more brittle than 1095, and I know that's just the nature of the steel. But I can't find anything to back up the claims it is ridiculously brittle. Can anyone with a D2 blade say whether they think it's way too brittle, and if it has chipped or cracked, and if it does roll and bend at all. Would you be able to pry things apart with a KA-BAR made from D2, or would it just snap? does it bend or flex a reasonable amount, or not at all? Please, only answer this part if you actually know for a fact (I am aware pretty much everyone on this forum would know more about steel than me, and there are some very wise and smart people here, but I would prefer an answer from someone who actually knows, rather than someone who thinks it may be too brittle).
2: If you did not consider the price of the knives, what would you go for? Is the D2 good enough for you to overlook a 1095 version if you were given one for free?
3: With the price of the knives in mind now, is the D2 really worth 2x as much as the 1095? And if I could somehow get it for the price of a 1095, should I go for it, or stick with the 1095?
4: Which one has sturdier construction? I know, the USMC went through WWII, and proved itself, but is the D2 going to stand up to more abuse than the 1095 (provided it didn't chip etc)? Again, I'm going back to the knife test videos by noss4 on youtube, but in the test of the USMC, the tang bends almost straight away, batoning through some wood. I know this is not what the knife should be used for, but in the same kind of test for the D2, it is not affected or damaged whatsoever. Is the 1095 a good tough knife and the D2 just excessively strong? Not that that would be a bad thing.
Also, would a leather or plastic sheath be better? If i get a leather sheath, it'll be black, but is the leather better for keeping the blade oiled? I know if it's unoiled and wet, a leather sheath will hold water, but does it hold oil the same way? Sorry about continuously posting new threads like this, people are probably going to get annoyed soon. But I want to get the best KA-BAR out there. Thanks.
I am no expert on the various steels but I can say that the harder the steel the more brittle it is. Saying that, the steel in a high quality knife is made to handle the use of that knife and if Kabar thinks that two good choices are 1095 and D2 then you should not worry about which one you choose. If the knife is used for what it is designed for then you should not run into any problems other than the harder the steel the more difficult it is to sharpen, but the better it holds an edge which may be a consideration. I have knives in all diffrent steels from file steel to the new super steels and have not had any problems with any of them. I will say I do like ATS 34, but that is a personal preference.
hi yes d2 is slightly more brittle than 1095, does that mean in normal use its gonna chip or break. No. its a good steel and holds up well. you can indeed pry with them and use them for anything a knife can be used for. Watching some guy chop into a concrete block really demonstrates nothing. I have never once found a need to stab concrete with a knife. The ka bars are stout well made knives either one will do anything you need it to.
as for sheaths, leather plastic or kydex its personal preffernce, put a bit of oil on the knife if its going to be stored a long time, otherwise just use the knife and it will be fine. Cut a steak with it, chop a branch, build a fire. your going to be fine don't over think this whole thing. Its a knife.
take it easy
cricket
You might also keep in mind that this is was designed as a combat knife, not a hunting or survival knife. It will work as one of course however there are many knives designed for hunting and survival that will do a better job with less effort.
take it easy
cricket
