t1mpani
Platinum Member
- Jun 6, 2002
That's fine and once again entirely your choice what you do with your knives, but perhaps you'll be willing to answer this question for me, it has been avoided thus far.
What use do you think IS appropriate for these knives that constitutes hard field use, or use that could not be as easily carried out by a smaller, thinner knife with a narrower profile? Now, I have plenty of knives that are thicker and heavier than the Beckers but 3/16" is nothing to sneeze at, and the 2/3 height flat grind used on the C/U7 is not optimized for cutting. That flat section of full-stock thickness running along the top is there for strength. Unless Ethan Becker and the folks at Camillus just don't have any idea of what they're doing, there has to be a reason for all of that steel there, right? I ask again, what use do you think is within the "appropriate" capabilities of this knife that couldn't be carried out by a 7" bladed butcher knife with a 1/16" spine, and would thereby justify the Becker's weight and the comparative loss of cutting efficiency? And again, I'll remind you that a butcher knife like the one described was used by me to split a whole mess of 4-6" diameter logs back when.
Edit to add: You might want to check out reply #8 in this thread where Ethan Becker specifically refers to the C/U7's chopping ability as well as the need to employ a baton for larger wood.
http://www.bladeforums.com/forums/showthread.php?t=184828&highlight=baton
