OK, I will give you my advise based on you being a new maker and planning on doing your own HT.
1) You will have to use a simple carbon steel. 1080 is the best choice. 5160, 1075, 1084, and 26C3 are all suitable, too. Get only one type steel. You need to make a good number of knives with that steel to learn the process.
2) You really should start with stock removal. Saw, file, grind the knife and do the HT. Finish up with lots of sanding using silicon carbide sandpaper.
3) Start simple. Don't try big or fancy knives until you have all the skills and HT down pat. Do one knife at a time. It is really silly to make the same mistake on four knives while learning. Each individual knife will be an improvement on the last one.
4) Start with a drawing of the knife and post it here in Shop Talk. Also tell us how you plan to make the knife (tools, methods, order of work, etc.). The folks here will help you fine tune the plans and drawings to get you a better start.
There are HT services available in London and other places in the UK, check them out, as HT is the most important step in making a knife. All high alloy and stainless steels need a proper HT done in an oven, often with a cryo treatment.
